Dodge Aries K Posted December 24, 2010 Share Posted December 24, 2010 Okay, I have a 1986 GL-10 wagon that I'm trying to have some fun with. This means that I'll reach the limits of it's EA82 turbo engine pretty quick because from what I see they pretty much suck. I tried searching for it but I couldn't find anything that shows if you can keep the air conditioning if you swap to the EJ engine in these older cars. If not, I will have to keep the EA82 alive as long as I have the thing as heat + me = heat stroke. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 24, 2010 Share Posted December 24, 2010 with some fabrication you could get the EA82 compressor attached to the EJ22 engine. work with the brackets and make something fit then route a belt to it. or the improper thing if you wanted to try it would be to include the EJ22 compressor in the swap and have some a/c lines fabricated at a shop. there are shops that make custom brake, compression, hydraulic...etc, i'd imagine someone can make these too if you take in what you need. you'lll have to convert to R134a which isn't a big deal since the system is going to be emptied anyway. or if you're lucky the fittings are the same and the routing is close? but i doubt it since it's R12 and R134a. Quote Link to comment Share on other sites More sharing options...
capn_r Posted December 24, 2010 Share Posted December 24, 2010 with some fabrication you could get the EA82 compressor attached to the EJ22 engine. work with the brackets and make something fit then route a belt to it. or the improper thing if you wanted to try it would be to include the EJ22 compressor in the swap and have some a/c lines fabricated at a shop. there are shops that make custom brake, compression, hydraulic...etc, i'd imagine someone can make these too if you take in what you need. you'lll have to convert to R134a which isn't a big deal since the system is going to be emptied anyway. or if you're lucky the fittings are the same and the routing is close? but i doubt it since it's R22 and R134a. Why is it "improper" to use the EJ compressor? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 24, 2010 Share Posted December 24, 2010 Why is it "improper" to use the EJ compressor?right, that is vague abe, that was more of a CYA than anything else. some folks frown upon people doing their own a/c work, those folks would probably also frown upon using a compressor from a different vehicle and different refrigerants, and they probably are spec'd differently. i do not know if it matters or not. i would assume it doesn't and try it. you being an a/c guy might be able to shed light on that? Quote Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted December 26, 2010 Share Posted December 26, 2010 (edited) folks that don't like people working on their own A/C system are the also the same ones that think a car that is over 5 years old shouldn't be on the road cos "its old"....they also have no imagination and want to drive an EV when they can't get public transport to where they need to go the EJ22 A/C compressor will work with the EA A/C system.... the EJ compressor is larger than the EA compressor...but not enough to worry about. make sure you have no leaks and enough refrigerant and oil in the system and your good to go Edited December 26, 2010 by LPGsuperchargedBrumby Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 27, 2010 Share Posted December 27, 2010 yea, should be just fine. In fact, using the EJ compressor would definitely be the way to go. Custom lines is not uncommon. Just go in with all 4 lines (2 from each donor car) and tell them what you want, and they'll crimp 'em together how you need it. If your EJ donor is new enough, you MIGHT run into issues using a compressor designed for r134a with the r12 system. But I think the biggest concern in the conversion is proper oiling for the compressor, so it might be better.... btw, the r134a conversion wasn't until the late '90s sometime, so there are lots of EJ cars designed for r12. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted December 29, 2010 Share Posted December 29, 2010 My turbo brat is running factory components with 134A. My VW Vanagon with 2.2L swap liked the Subaru compressor. I have done a 2.2 swap for a customer on an 88 RX and that car had BETTER A/C after I was done than brand new according to the customer. You will need to be very careful not to overcharge it, and I highly recommend putting a Receiver drier that is 134 compatible in while you are at it. I did it with the factory legacy one with no issues on the 88 RX. Quote Link to comment Share on other sites More sharing options...
Dodge Aries K Posted January 13, 2011 Author Share Posted January 13, 2011 Oh wow, that's great news to hear all around then. I was halfway tempted to just give up on the car and say screw it (lots of unpleasant situations around here with my house and other things) but that makes me want to try to fight for it a bit more. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted January 13, 2011 Share Posted January 13, 2011 The biggest hurdle is finding a good hose company to make the custom hoses. After that its pretty easy. Compressor to custom lines to original evaporator and condensor is usually easiest. Putting a 134 receiver/drier is also a good idea. Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted January 14, 2011 Share Posted January 14, 2011 What about refrigerant oil when converting a system like this? Using an EJ22 comp, 134a R/D with an R12 system (and 134 refrigerant) couldn't you just use ESTER oil to be safe or should you use PAG? Just some thoughts... Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 14, 2011 Share Posted January 14, 2011 systems are swapped all the time, so yeah just google it and roll with what folks are doing. i've done it before and while details are scarce in my head i'm sure i could figure it out in about a minute on google or here (if i wasnt' on dial up right now ). i just did what you said - added compatible oil and all was well. Quote Link to comment Share on other sites More sharing options...
capn_r Posted January 14, 2011 Share Posted January 14, 2011 I've done a lot of R-12 to R-134a retrofits and pretty much exclusively run ester oil. Castrol makes what they call "retro ester" that I'm not aware of any failures resulting from its use but I also get ester oil from the local napa. From my experience if you use pag be sure and wear protective gloves and eyeware, I have scars from getting some pag oil on my hands that Kenworth used in the mid 90's, it's nasty stuff. Quote Link to comment Share on other sites More sharing options...
