March 1, 200422 yr Which are the pug wheels that I need special lug nuts for? I found a set of 4 steels and a pair of alloys in the local jy.
March 1, 200422 yr The 15" alloys require the use of their respective lugnuts. The 504 14's also have a special washer/nut combo. The 505 steels(both 14 and 15") use standard acorn style lugnuts. The 14" alloys from the 505 can also use standard acorn lugnuts.
March 1, 200422 yr My 14" alloy pugs HAVE TO HAVE the special "Ball seat" lug nuts, acornes will not work at all:( I'm not sure what model they are off of, but they are the most common ones.
March 2, 200422 yr Tony, not to step on toes but the 14"ers came with acorns or open lugnuts on the Peugoets. It may have had the "ball" washers when you got them but I have seen/used them with acorns. If you compare the seats in the wheels between 14's and 15's you'll see the difference.
