January 21, 201115 yr I Believe that the Owner is the one that Owns this Website: http://subarubrat.com/ Edited January 21, 201115 yr by Loyale 2.7 Turbo Spelling
January 21, 201115 yr Author thanks, it indeed was. helped some. My big question is this...Did he flip over a rear subaru differential for the front, or is it sitting in its normal orientation?
January 21, 201115 yr it's a former members. it's been long sold now... the subaru diff in the front it still oriented the same way it was in the back (not upside down). the transfer case is where the rotational change is. there are a few others on the board here with a t-case lift that utilized the diff in front like that.
January 21, 201115 yr Author Mcbrat, do you think this would work if I simply swapped out the front and rear subaru diffs for some ford 8.8 IRS diffs from tbirds/cougars, etc?
January 21, 201115 yr If you have fabrication skills then yes. If you are paying for someone else to do it, probably not. Do you plan to run ford axles? Why not go solid axle if you are going to that extreme?
January 21, 201115 yr Author ive always been a big fan of fully independent suspension. its something i think would be superior over straight axles if it didnt have the dependability issues. that and its always been my dream to race in the baja...so maybe someday.
January 21, 201115 yr Author here is what i have planned: Ford 8.8 IRS Rear diff in the rear, full double a-arm suspension, 97+ f150 4wd front spindle/brakes (yes, front spindles on the rear, would be anchored for no movement, but would be capable of being used on rear wheel steer down the road), custom axles (Unless factory tbird axles are long enough), 12-14 inches of travel Ford 8.8 IRS Rear diff in the FRONT, full double a-arm suspension, 97+ f150 4wd front spindle/brakes,custom axles 12-14 inches of travel I feel it wouldnt be much more difficult then straight axle. I would make a custom crossmembers that would have all the mounting points for everything but bolt to factory locations. Would probably have the top shock mounts attached to the subframe so the unibody isnt experience the beating of long travel. like this bmw only with a subie:
