Rear Main Seal... What Tha??????
So, I have the engine out of the 83 Silver Brat. I take off the fiywheel and stare do a double take... Because there are TWO rear main seals nestled on the crankshaft.... What's Up With This???????? :confused:
The hub that the flywheel is bolted to, is pressed on the crankshaft, so Subaru used two seals.
Mystery Solved. It's not a main seal... It's an o-ring... An extremely flattened o-ring!
Whats the purpose of that o-ring? Just wondering...I think I have put flywheels on without that o-ring in place.
Doh...Never mind. I just re read GLCraig's post. That explains it.
I think its a machining change but am not sure. Most I have seen with it had hydraulic lifters but I haven't taken the time recently to do a verification of that.
I've taken apart two EA81s with solid lifters that had that O-ring. I'm not sure, but I think they all have it.
My 85 Brat with Hydro lifters did have the reddish orange seal, and i replaced mine with new it had a tear in it.
Is there any way to tell if a motor has hydro lifters besides popping the valve covers?
My EA81 '84 GL has the flywheel O-ring, but I was under the impression it had solid lifters :confused:
with the flywheel o-ring removed:
hydro motor has stickers on the valve covers. sticker says, do not adjust valves.
