My BRAT Build Up Thread
Working on getting a baja style tailgate built for it. I'll post some photos up after I get that installed.
  • 5 months later...
  • Replies 80
  • Views 23.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
Posted Images
Bill and I just dropped this little baby into the BRAT:
1005301_10201702618477170_1242947330_n.j
470527_10201702619317191_1398821836_o.jp
177359_10201702619797203_1997772448_o.jp
1006198_10201702620157212_1509822361_n.j
944511_10201702620637224_1736711077_n.jp
1026120_10201702621917256_2062823925_o.j
177386_10201702622597273_2015628311_o.jp
Its a 3.9 XT6 R&P, RX gear set, 1.59:1 low range gears in an RX case with FT4WD and diff lock. It pretty much rocks :headbang:
Edited by Pooparu
The only thing that kind of sucks about installing the transmission is that we had to kill the smoke stacks for now. I'll have to build them again later.
Yeah, that part sucked, but after 24 hours of continuous working, it was just :banghead: when the pipes hit the tailsection. Never even considered the FT4WD tailhousing wouldn't hit the pipes...
Great lessons learned from this project though :burnout:
-Bill
Yes indeed. That was one long messed up build. I was talking out loud to nobody on my ride home. I was super loopy.:rolleyes:
-Bill
  • 11 months later...
Installing a frankenmotor (EJ25 block with EJ22 heads) with delta cams & I'm adding some power steering too. This should be fun.
Good-bye good old EA81 (over 300,000 miles and going strong).
1045029_10201669063278311_2021946179_n.j
970262_10201702538675175_1436201411_n.jp
1010349_10201702539195188_1165003190_n.j
Some of the many parts needed for the swap
1044335_10201669063638320_444155006_n.jp
EJ25D block
968835_10201669064038330_1663467550_n.jp
Rebuilt EJ power steering unit.
Fresh EJ22 single port heads with Delta Cams installed
1044672_10201702539755202_211769690_n.jp
ARP head studs
1004601_10201702540155212_365925484_n.jp
Super dirty EA power steering stuff
1045097_10201669064478341_150366467_n.jp
More photos and updates to come very soon.
Edited by Pooparu
Some other ramdom photos of the BRAT.
1011696_10201494860043339_214840286_n.jp
Edited by Pooparu
No, I'm going to clean it up and install it into my BRAT.
Ahh, I thought you pulled it from your Brat. I figured that's why it was dirty B)
  • 2 weeks later...
Interesting roadblock today. I'm using ARP head studs for my build and here's what happened:
Too darn short. Anyone ran into this before?
Sooooo.... from what I can tell there is a difference in length on head bolts on the EJ DOHC & the EJ SOHC heads. I have head bolts for the DOHC heads and since the EJ22 uses a SOHC head you need to get longer head bolts. :wacko:
Bummer about the studs! Nothing like a fun little snag when you are all amped.
With that setup and cams what are ya thinking for output? 220ish?
Hoping for at least 190 - 205 range (crank)
Some video of my BRAT at last years WCSS
Right on!  WCSS seems like a killer time.
Gotta love the Loyale Wagon running over (and getting stuck on?) the Celebrity.
Irony in it's finest.
Got the block cleaned up and the heads put on today.
Got the power steering in today.
1146408_10201918625917221_1229838845_o.j
Any bets on the dual ranges life expectancy?
I will say he takes it off pavement twice before it pukes.
Edited by Mykeys Toy
Just picked this up for the frankenmotor. It's a water cooled oil cooler.
965896_10201937792476373_1744806317_o.jp
Did you get a different (longer) set of ARP studs and if so what is the part number? Thanks!
