July 2, 201114 yr Well, last night I changed my spark plugs, wires and pcv valve on my 95 Outback and decided I would drive it today to work. This morning I stopped and filled the tank up. Coming home, I backed into my driveway and noticed I was leaking fuel like crazy. I immediately remembered all the threads on the rusty fuel filler neck rusting out and figured it had bit me too. I jacked it up at the rear diff and took the plastic guard off. A person could grow vegetation in there due to all the crap. Since it is the holiday, I have to wait till Tuesday to order a filler neck from the parts dept. My main question: can I replace the filler neck without having to drain the tank? That thing is sitting just a smidge above full on the gauge and worried it would dump it out when I start to remove it.
July 2, 201114 yr Mine would still leak driving until I got under 1/2 tank.. I'd say under 1/4 to be sure
July 2, 201114 yr Author It's not leaking sitting in the driveway right now. I just worry about it pouring all the fuel out when I take the old filler neck off.
July 2, 201114 yr yeah it wont leak after the fuel stops moving around and because it's under the lvel where the hole is.. What I'm just saying just get it as low as you can.. Not sure how far you are from the gas station but tryin doing it when the gauge is on Empty.. trust me I can run my car till it's almost resting on the peg.
July 3, 201114 yr You can run the car till it's way below resting on the peg... then you can sputter along for another 5 miles to the gas station. I think dealers and shops that know subarus tell you to take it in under 1/4 tank. I did mine at just below 1/4 tank and was fine, I definitely would NOT remove the filler with a full tank.
July 4, 201114 yr The fuel filler goes into the top of the tank. You may lose some fuel, but only until it is below the top of the tank. So, if you have the tank over filled, it may lose a little bit. I wouldn't worry about the amount you will lose though. Just get another neck and put it on.
July 4, 201114 yr You can run the car till it's way below resting on the peg... then you can sputter along for another 5 miles to the gas station. I think dealers and shops that know subarus tell you to take it in under 1/4 tank. I did mine at just below 1/4 tank and was fine, I definitely would NOT remove the filler with a full tank. have you ever looked inside the tank from Full to half a tank? not that much different visually..
July 8, 201114 yr Author I got the parts in yesterday. I had every intent on doing the job when I got home from work yesterday except it came a thunderstorm on my way home so I said screw it. 2 hours later I got stir crazy and decided to tackle the job. Aside from it being a real tight fit, it wasn't that bad. I did notice one thing between the old part and the new one. The old one had an orange flapper valve at the end of the neck where it met the gas tank hose and the other one did not. I didn't want to develop some issues where the pump would not kick off when fuel was almost full so I swapped it into the new one. Better safe than sorry. it caught me off guard because every post I read did not mention that valve.
July 8, 201114 yr I think that the flapper valve is really there to prevent someone from siphoning off your gas tank. A product of the gas shortage when gas tanks were being emptied at a regular rate.
July 8, 201114 yr Author Got ya. Oh, and I did change this thing with a full tank of gas. The only fuel that was last was maybe a cup that was in the fuel nozzle itself.
July 14, 201114 yr Must have a level ground? the filler that goes to the tank does not go that far down.. you would only have issue if say your driveway was on a incline.
July 18, 201114 yr Author First time checking this thread in a while. We welcomed our first born on Wednesday, little boy. Trying to adjust to the new swing of things. Yeah, it wasn't a fun job to do in my driveway at 9 at night with a flashlight in my mouth.
July 19, 201114 yr I got one of those Energizer LED headlamps (3 LED) best $14 I've ever spent.. like you I got tired of the flashlight in the mouth It's so awesome to have free hands!
