Torque Bind Cured!
1992 Legacy Auto Wagon 180K
Cured with a simple drain and refill, three times with fresh tranny fluid. I know it's been said a million times to change out the fluid to possibly cure Torque Bind, but I just wanted to ad my two cents. And it was pretty bad TB. Completely gone now.
I went with the cheap, house brand fluid at O'Reilly's. Sold in 1 gal jugs for about $15. Coincidentally, a single "drain" drains about a gallon so that was pretty handy to drain a gallon, add a gallon. The last two 4eat's I messed with, I used a much more expensive brand of fluid. Seems the Board Advice is, that's not necessary.
Man I love these early Legacy wagon's. For the money, I just don't think there is a better car on the road. Good thing they'r so Ugly, else everybody would want one. :lol:
Steven Likes this post.
I found a fluid change like that to definitely alleviate TB and other binding issues like that in a 4EAT. Also try some of that Lucas stuff...with the one I used to own (high miles) the more of that stuff the merrier....
--Damien
Thats always the first step on any sooby tranny issue where the car still moves :)
  • 4 weeks later...
2001 Forester 108k miles. Manual Tranny.
I am getting torque bind now when the car is warm, not when cold.
Exactly which fluid should I be changing where?
Exactly what is the fluid called I should use?
thx.
Edited by unibrook
thx.
fluid change doesn't apply to you, you have to fix the trans by replacing the VC.
in a manual transmission the center viscous differential fluid is in a sealed, non-serviceable unit and the fluid is not replaceable. the fluid you drain from the trans has nothing to do with the fluid in the center diff.
the auto's and manuals work *completely* differently, they are not related in any way at all. so what applies to auto's does not apply to manuals.
in your case there is no cure for torque bind except to replace the center diff with a used or new unit.
or wait until it completely fails to permanent locked and remove the rear driveshaft and run it in FWD.
or wait until winter...maybe it'll be less noticeable in the cold, or won't matter when the white stuff starts flying!
Ok, thx for clearing that up for me.
Given the expense of replacing the center VLSD, I will probably wait until it gets really irritating, then go this route:
"or wait until it completely fails to permanent locked and remove the rear driveshaft and run it in FWD."
Is that really doable with no ill side effects? Cuz, I really do not need the 4wd.
