My '92 Landcruiser: Safariwagon-II
  • Replies 320
  • Views 72k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I know I'm quoting a really old post but I just have to say. . . . Hell's is a pretty sweet trail!!  Its one my buddy (black FJ80...you've seen pix before and chatted with him on other forums) and I
  • TheLoyale
    TheLoyale
    So its been a while. Installed a factory ATF cooler, painted the hood matt black, and am going to take it down to Chenoa, IL soon.     READY FOR ADVENTURE...!
Posted Images
Some advice for others who plan to swap springs/shocks. In order to lower the axle enough to remove the stock springs, you will need to remove the 6 12mm bolts which retain the Brake line to the axle to gain more slack in the soft line that runs to the frame. Other wise you will over stress it and possibly rip it. You will also want to drop the Swaybar mounts enough so the Drive shaft doesn't get hung up while lowering the Axle.
Also, if you plan to do this without using a vehicle lift, you will need two 3-ton Jacks to raise and lower the axle evenly, and a pair of 12-ton Jackstands (Or at least a jackstand that has a total length 30" inches) to place under the front frame rails (Where the toe hooks are)
This went a lot easier then I had in mind, but once you unbolt the stocks and start to lower the axle, its all a cake walk after that!
Tools I used so Far:
Pair of 3-Ton Standard Jacks
Pair of 12-ton Jackstands (HF)
HF Electric Impact Wrench
1/2 drive Ratchet and Extensions
1/4 drive Ratchet
10mm 12mm 17mm 19mm 21mm Sockets
Few pictures of the front install.
Looking good! reading this makes me really want a FJ80!!
OME lifts are very nice, looks like it was a pretty straight forward installation.
can't wait to see what it looks like with the rear done as well.
shovel hoodprop?
is that a accessory?
looking nice you got a nice rig to work on.
Hell yeah :lol: Eh, the Struts don't hold to well in 20 Deg. F temps :slobber:
shovel hoodprop?
Nice job, but 12ton jackstands seems like overkill to me. Its not a bigrig.:grin:
If you would have "Read" my post, you would have understood why I used 12-Ton JS.
Because a 12T harbor freight jack stand is actually only good for 3...?
NICE and quick... Did you ever chat with my buddy on the LC forums? I think he suggested tire siping those MTs (I now know you can't get it done locally), etc. but he's got good beta on lifting, and how the rear end shifts laterally, and how you might have to shave clearance for the front sway bar, etc. etc.
(I don't remember all the specifics but I know there's is some stuff you may encounter and need to deal with)
Maybe that's b/c he went custom 4" though. . .
Either way, nice job, sweet turn around and direction on this one.
I need a jackstand that will rise over 30" to support the frame while the axle(s) drop. But yes, I'm sure a 3-ton HF Jackstand is only good for half that :drunk:
I might have ran into him on ih8mud, don't remember. Some dude with an FJ80 added me as a FB friend lol. As for you buddies lift, Is he running more then just springs and Shocks? After 4" you will need to add spacer blocks to lower the rear most points of the front swaybar (To avoid running into the Driveshaft under flex) along with dropping the rear swaybar, longer soft line from axle to frame junction box, longer diff breathers, Might have to change pan-hard and lower links and then you will also need to use the Caster correction bushings. Sleeoffroad is the way to go with Toyota lift kits, they provide everything you need and they know "EVERYTHING" you could ask.
Pictures to come next.
The Result. B.A.D.A.S.S :slobber:
33" of rubber, no big blades for this SUV!
The deepest creep you will ever meet!
Now my Mom wants to lift her FJ lol! She can't stand my Toyota being bigger than hers :lol:
I like that rig very much... So much in fact that I'm actually going to start the hunt sometime after my Loyale project is done.
Curiosity, ballpark how much are you into this thing??
Spencer
$3,900 for the truck. $1,000 for tires, $900 for OME Suspension, $200 in tuneup/etc. $30 for JDM Corners and Blinkers.
Spencer
That's very reasonable for what you've got. I have almost that into my 84 single cab pickup and I think your rig is cooler.......
'84 Hilux? Oh wow nice! 22R? My mom dad an '88 22RE 5spd (Nice lift)
Brent, I don't think it'll tuck up under there to good, it might though. Need an ARB bumper/swing arm!
Ya, 22RE! (swapped), there's a thread on here about it in the non-soob offroad. I'll be updating it as I progress. I've read your whole thread and really admire your work with this rig. It's the "closest" I've been to one of these now (thanks for the pics!), and pretty much my mind is made up about owning one. Just a matter of when I suppose.
Yeah i h8mud sounds familiar. Probly the only 80 from Moab there ;)
Yeah he custom built the blocks and caster correction, etc. etc. Kind of a pain but he got that figured out, for a little less than a complete pre-fab 4" kit. Thing is (out west at least) most people go 6" and he didn't want to go that big, so he got springs and figured the rest out...
But sounds like you got all the weird stuff figured out, and your milder lift probably doesn't have as many of those issues to deal with.
'T looks good man!
'91-'92 FJ80 with the 3F-E and A440 trans is kinda what you'd want. Doesn't have the locking diffs, but the 4.0 is way better than the DOHC 4.5 1FZ-FE, as they tend to have HG issues, and use a timing chain. The 3F-E have Timing gears (Like a EA81) Bullet proof :)
I would checkout ih8mud.com and read up about them, pros/cons, what to expect, what to look for ect...
-Tom
