November 3, 201114 yr Hi all! Yes, I did the Search thing and I only got Li'l confused; so I must start a New Thread in order to find the Right answer. My BumbleBeast has this Setup: Front Suspension: 4WD Subaru Shock absorbers Plus Ford Tempo Coil Springs. Rear Suspension: 4Runner Shock Absorbers plus Honda accord Coil Springs. (that makes a 2" Lift) Fifteen (15") inches Rims.(Details about my Suspension mods, could be Found here) So, The Rear became Taller than the Front... But Now I am about to install a SJR 2" Lift Kit for the Front of my Wagon, (More Details here) So my BumbleBeast will be on Level. The Question I Have is This: Which Size of Tire is the Maximum (Tall & Wide) I can Run on my 2" Lifted BumbleBeast Without trimming? Now it Runs unlifted on 205/60 R15. I'll Like to know which Tire sizes run on 15" rims, people who has 2" Lifts on their EA82 Subies. Kind Regards. Edited November 3, 201114 yr by Loyale 2.7 Turbo white words are links
November 3, 201114 yr i have 28" firestone winterforce on my 91 loyale w/2" lift (205/75/r15). i still had to trim tho. RV
November 3, 201114 yr Author Thanks! You had to Trim... Could I ask you Where and how much? I Don't want to cut the Fenders... Do you have Pics? Edited November 8, 201114 yr by Loyale 2.7 Turbo mispelled word
November 3, 201114 yr im currently unable to get any pics up w/o a pc at home. you can search my posts/threads. my fenders are cut similar to One Eye's yellow wagon. I will say this tho, I cut my fenders before getting those tires. I origionally had 235/75/r15s and couldnt cut/beat enough to make them fit so all my info is potentially worthless. sorry about that. IMHO if you wanna go bigger and not cut fenders (your car rocks, my car is beat and ugly) i would go taller. others can help out. hth RV
November 4, 201114 yr What kind of rim are you using? It would make a difference, my 27" tires need quite a bit of triming because i used a wheel with a bit of negative offset.
November 4, 201114 yr good point VB, im using '91 mitsubishi (i know) montero wheels. the offset is real close to stock offset. RV
November 4, 201114 yr I have 27 inch tires with a 2 inch lift. I wouldnt of had to do any cutting if i had the lift on before the tires. I have peugeot wheels so my offset is real close to stock. If your running anything else you will need to cut a bit.
November 6, 201114 yr Author What kind of rim are you using?... Good Question, They're Very Close to Stock offset, but 15" alloys; you can see them in the Picture attached on the link below, or by Clickin' on my Signature; those are in my "BUMBLEBEAST" Subaru. http://www.ultimatesubaru.org/forum/album.php?albumid=51&pictureid=3242 I have 27 inch tires with a 2 inch lift... Could I Kindly ask you, Please, to give the Tire's Measurement in the Standard Format? ... I'm not Sure which size is 27" Now My Bumble Beast has 205/60 R15 I don't know how to Measure them to tell you if they're 25", 26" or so... Kind Regards. Edited November 6, 201114 yr by Loyale 2.7 Turbo to add the Picture's Link
November 6, 201114 yr Your 205/60/15 is about 24.5 inches, a 215/75/15 is 27.6 inches, 225/70/15 is 27.4 inches.
November 7, 201114 yr Author Thank you! I Found a Good Deal with a Set of 225/65 R 15 all terrain Tires but I am Not Sure if those are gonna Rub... so I haven't decided yet if I Gonna buy them. I Just Found a Nice on-line Tire Size Calculator... ...Here: http://www.net-comber.com/tirecalc.html
November 7, 201114 yr Author So, maybe my Tire Size Question must be Asked in Overall inches Size... Which size is the Biggest & Widest I can Go Safely (Without Rubbing nor Trimming) on my 2" Lifted BumbleBeast? ... ... 27" ?
November 7, 201114 yr 27's are pushing it.... 215/75/15 might be able to fit, but it might rub the fenders under full compression... a 225/60 or 225/65 probably wont rub and gives you the widest tread that can fit. i also know that you will have to trim and bash for hours to get a 235/75/15 to fit without rub, lock to lock. how opposed are you to "massaging" the inner fender well with a BFH? you should be able to get an even bigger size to fit without cutting the finders themselves.
November 7, 201114 yr Author Thanks for the Answer, so 27" are too big. I'm a Li'l Lost in Translation with This: ...how opposed are you to "massaging" the inner fender well with a BFH? ... You mean to Hit the inner Part of the car (that is the Floor) to fit a Bigger Tire? Well... it could be done but a Little in order to avoid deform it to a noticeable way. Could someone Post Pics, Please; of their Big Tire Setup? Kind Regards.
November 8, 201114 yr I had to Trim to make these tires fit. They are 27x8.50x14 with a negative offset, Jeff (one eye) has a set of 27" wildcats on peugeot steels and they rub very little with no trimming.
November 8, 201114 yr 215-70-15 is great!! lots of good a/t tires come in that size. its big enough. wider without really being too wide, and tallish without killing trannys or hurting acceleration too much. i also lean toward medium sidewalls. thats why i went to all the trouble of getting 15s when i couldve just thrown 27x8.5x15s on, and got the same overall dimensions. the 215-70-15 is supposed to be 26.85. with a sidewall a half inch shorter than a 215-75-15. i wish someone would make some strong, light, affordable 16x6s in 4x140mm. then id just run 215/65/16s.
November 8, 201114 yr 215-70-15 is great!!lots of good a/t tires come in that size. its big enough. wider without really being too wide, and tallish without killing trannys or hurting acceleration too much. i also lean toward medium sidewalls. thats why i went to all the trouble of getting 15s when i couldve just thrown 27x8.5x15s on, and got the same overall dimensions. the 215-70-15 is supposed to be 26.85. with a sidewall a half inch shorter than a 215-75-15. i wish someone would make some strong, light, affordable 16x6s in 4x140mm. then id just run 215/65/16s. 6-lug wheels come in 16x6". Redrill to 4x140mm. Problem solved.
November 8, 201114 yr Author I had to Trim to make these tires fit. ... Thanks for the Pics, those Tires are Good Lookin' and somehow they're like the ones I Wanna Run on my BumbleBeast. So, Those are 27" and your Subie has a 2" Lift, isn't it? ... if so, it looks like Too much Trim for me. So what Tire size do you Suggest to me? ... 26"? ... Could 215/65 R15 Work? Kind Regards.
November 8, 201114 yr toyota wheels are toooo heavy.... and i dont like the way the centers look with the empty holes and lack of center caps. it just doesnt suit my style.
November 9, 201114 yr Author well... Back on Topic: Could 215/65 R15 tires Work in my BumbleBeast? or Shall I choose 215/60's? Kind Regards.
November 9, 201114 yr well... Back on Topic: Could 215/65 R15 tires Work in my BumbleBeast? or Shall I choose 215/60's? Kind Regards. I think I would run 215/60s or maybe a 205 series?
November 10, 201114 yr Author I think I would run 215/60s or maybe a 205 series? ... Now it Runs unlifted on 205/60 R15 ... Back to Square one? I want to See other 2" Lifted + 15" Rims Loyales and know how Big they can go with Tires without Trimming nor Rubbing. Kind Regards.
November 10, 201114 yr Author 215/65 R 15 are 26" according to the Tire Size Calculator, so Does anyone Run a 2" Lifted Subie with those? ... are those gonna Rub? Kind Regards.
November 11, 201114 yr use this to help figure it out http://www.miata.net/garage/tirecalc.html y hola! amigo, que tal? I'm running a 205/70 - 15 but it's a 4" lift, no trim. I do rub on maximum lock, just barely. I may be going to a low profile 16" because I can get some really nice rims for cheap. Using that tire size calculator I can find a smaller outside diameter and lower sidewall even though it's a larger inner diameter. Tengo gusto de visitar Honduras, pero esté peligroso a través de México! (mas o menos, 'babel fish' no esta exactemente, lol)
November 11, 201114 yr Author use this to help figure it out http://www.miata.net/garage/tirecalc.html ... Thank you... I already know that 215/65 R 15 Tire will be 26" ... the information I need is if my 2" lifted Wagon will have enough space for those tires without Trimming nor Rubbing. ...y hola! amigo, que tal? ... ¡Bien, Gracias! ...Tengo gusto de visitar Honduras, pero esté peligroso a través de México! (mas o menos, 'babel fish' no esta exactemente, lol) Well... Babel fish works somehow like the Google Translator. You're Welcome to my Beautiful & crazy Country, I hope that you'll Like it! Please, let me Know where you want to Stay, so I can go visit you with my BumbleBeast Subaru Kind Regards.
November 12, 201114 yr Thanks for the Answer, so 27" are too big. I'm a Li'l Lost in Translation with This: You mean to Hit the inner Part of the car (that is the Floor) to fit a Bigger Tire? Well... it could be done but a Little in order to avoid deform it to a noticeable way. Could someone Post Pics, Please; of their Big Tire Setup? Kind Regards. one thing you will have to do with that hammer is flatten the seam in the wheel well, and a bit on the inside so that you can retain a full lock to lock steering. you can get away with a tad of hammering without anybody noticing anything. like i said, "massaging"
