November 24, 201114 yr these where taken with an android phone to so they may not be the best of quality but it shows what he did and where he covered up the hole where the shifter should be and how he changed it Like you said it is a little difficult to tell whats going on there from the photos, but it looks to me like an automatic to manual transmission conversion or FWD to 4WD conversion. I have honestly never heard of a FWD Brat, so I'll go with auto to manual. Edited November 24, 201114 yr by ferox
November 24, 201114 yr Didn't the '81's have a "Single Range" transfercase? I'm not sure. But it could be your's had one, and it was swapped to a D/R 4-speed. Pics look like standard D/R 4-speed shifter setup, minus that added plate.
November 24, 201114 yr Most likely the original gearbox (which in a '81 would have been dual range) 'gave up the ghost' and was replaced with a later 4 speed dual range transmission. EA81 engined Gen 1 Brats/Brumbys were only produced for around 12 months so the gearbox is not exactly plentiful... (The front half of this gearbox is the same as all EA81 4 speed dual range transmissions but the rear is like the old EA71 single range - this was done to keep the original 'twin' shifter arrangement for the old Brat/Brumby body) Perhaps the lever just needs adjusting? You can adjust the shifter rod on the original gearbox quite easily so I assume you can on the later lever type too.
November 24, 201114 yr Author the lever you see in the pics is total crap cuz if i tighten the mounting bolts so theres no slop then you can't engage or disengage 4WD he drilled through the tunnel to mount that set up so it's total crap..and my step dad thinks he swapped a different tranny in too so idk..but i really wanna do the 5speed d/r upgrade so bad
November 24, 201114 yr Now you have an excuse to do the 5 Speed D/R swap and do it your own way, one that works with you, and if youre nice, one that will work for the next owners (if you decide to sell the Brat)
November 25, 201114 yr Author im not sure i'll ever sell my brat...and i need money before i can do it i'm only 16 and i'm pushing to find a job but the way things are right now i can't get a job and i've filled out many apps so far and still no luck
November 25, 201114 yr Author okay so what years did they make the brat cuz i know they started in 78 to 81 with the first gen but how long did they last after that cuz i just saw a thing saying a 93 brat for sale and i dont think they made em up til then
November 25, 201114 yr 82-87 in the USA, but they were available up to model year 1993 In Australia, New Zealand, and a few european areas.
November 25, 201114 yr Author really they made em that late wow...did they have a third gen brat over there???
December 1, 201114 yr Author okay so what 5speed d/r tranny would be the best for my 81 brat like what year and what engine is it off ect.
December 1, 201114 yr okay so what 5speed d/r tranny would be the best for my 81 brat like what year and what engine is it off ect. '85-'89 EA82 engine...the boxy looking wagons and sedans. Later versions of that car had a single range 5MT. I believe '88-'89 would be easiest. Jerry aka Bratsrus1 sells a kit to make the swap easier in case someone didn't already mention it, at least I hope he still makes them.
December 1, 201114 yr Author alright thanks..i'm just trying to get info so once i get the money i can go out and buy the stuff to do it right away cuz i really wanna do this...it well prob be the only mod ill do to my brat minus a one or two inch lift on it
