January 17, 201214 yr I have a 99 outback legacy, if I get a 4 inch lift will I have to do anything else like with the drive shaft or can I just leave it stock??
January 18, 201214 yr are you planning on changing wheelbase? try searching. loooooots of threads on here. try google too, it usually spits out usmb stuff anyway
January 18, 201214 yr 4" Lift on a true Outback (meaning, True outbacks have the longer struts, longer steering shaft, and Crossmember spacers) Adding an extra 4" on top of that, and you will need to drop the Front and Rear Crossmembers down more, Longer Steering shaft (Steering column to Steering box) You might need longer soft lines from the brake caliper to the hard line junction on the inner wheel well. And when dropping the front crossmember/motor, you might need to drop or extend the pitch bar for the bellhousing, also might need longer Radiator hoses, alter the intake box somehow with a longer intake tube... The center Driveshaft will not need to be lengthened, unless you are going to change wheel base and go total custom wheeling rig. Edited January 18, 201214 yr by TheLoyale
January 19, 201214 yr You'll need to drop the center bearing down an inch or so and flip the carrier over, lengthen the pitch stop and steering link and might as well do the brake lines too. Not sure if you're a stick or auto but don't forget the linkages for the trans., I dropped mine down around an inch and also pushed it forwards for less binding (5spd stick baby!) Nipper had a good write up on what he did for Blu. and I used it as a guide for mine.
