Retro GL-10 TURBO build
got the turbo sorted out so the wastegate won't hit the wall
SS feed lines and fittings so never rust
got my PROvent 200 all set up so it can catch all the oil
also add the radiator cap on the radiator like the factory had it so its clean and works flawlessly
2 x 12" opal fans made in Italy, the driver side has a bigger HD motor then the slim passenger side
  • Replies 479
  • Views 154.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • a company in the usa makes them out of fiber yours looks to be the same        so
  • well the manual rack wont fit... I lowered my motor so the sti 6mt would fit and am using the longer u joint any ways when the manual rack is there i would need even a longer u joint... i have a leone
  • my guys are so busy they made mine and told me its going to be a while.. but i have another way of doing this with out costing so much which you will see in the wagon build i have going on... got new
Posted Images
Setrab oil cooler fits so nice ill have to convert the sedan to this model soon
these Subarus don't really have a proper toe adjustment so I came up with a heim joint with threads so I can adjust the Alignment much easier, and its all made out of SS so it will never rust
original subaru leone
Version 1 : hard to adjust live on the alignment rack.
Ver II perfection ! ;)
made this long time ago for the bushings in the arms now the wagon will have all pillow ball heim joint ride like the sedan
ordered up the aluminum tubes for the intercooler and radiator pipes
first step was get the radiator pipes made up, lower & up pipes for both sedan and wagon
more alignment goodnesses stuff in SS, radial rod fully adjustable for caster & centering the hub under the body of the car.
DANG! so awesome.
is that a caster adjustment you modified?
also, I don't see you using the 'alternate' hood prop in any of the pics. You can move it to the xtra hole on the piece on the pass side strut tower. I THINK on some older models, you also flip the rod over.....?
I used it on my WRX when I pulled the TIC.
