March 26, 200422 yr whe I pin it in my wagon,it pulls to the right but the steering wheel is still straight.Is it the drag in the rear diff pulling me that way or should I be checking something out?
March 26, 200422 yr It shouldn't be torque steer. Our Subarus have equal length halfshafts so we don't have "MORE" torque making its way to one wheel on a regular basis. could be that the engine's torque is lifting the right side of the car, unloading that wheel. My Benz does this, and it usually spins the right rear tire unless I'm turning.
March 26, 200422 yr take a look at the rubber mounts holding the steering rack into place, I find this often is the problem in my wagon. Try grabbing the wheel in the front and back and see if you can change the wheels idirection, it will be even easier if you jack up the car. Matt
March 26, 200422 yr I think the engine is jacking up, changing the geometry on the front drive axles. Check your right motor mount. Then tranny mount. Jay And don't forget to post your fix when you find it. Good Luck.
March 26, 200422 yr torque steer ive noticed in my wagon will pull left, then right and even out. the equal length half shafts HELP but there is still torque steer. just seems that it evens itself out. unlike in my KIA (transversly mounted engine/transmission) where the uneven lenght halfshafts make it pull hard to one side and I end up fighting it with teh steering wheel.
March 26, 200422 yr I find my wagon scrabbles like a cat on a hardwood floor when in 2WD and the surface is a bit slippery (rain, sand, etc.). Firs one side, then the other, oscillating teh gripping wheel back and forth several times before hookng up. My buddy's EA81 did it way worse, though. My AWD Corolla never did it. Probably because of having only 1/2 the torque at any wheel. Yay AWD!
