Evil 97 OBS
Okay, okay, probably not as evil as some, but definitely a lot of fun and enough to get myself into trouble with.
My initial expectations of this car were to be a reliable, family friendly, grocery grabber with the ability to get up in the mountains and save myself from putting 10k miles a year on my CBR.
I purchased it from a very 420 friendly girl for $1500 with a cracked windshield, dead tires, interior that was atrociously dirty, and eau de pot. On the plus side; clean title, new transmission, and cheap cheap.
Washed it, buffed the paint out, straightened the hood a bit, and threw a set of 2005 WRX wheels on with some new rubber. Got the windshield fixed and went through a bottle of Febreze. Shaping up to be a nice little car.
But then, things got out of hand.
I had a thunk under hard acceleration, the clutch slipped, and the rear end rode like a lincoln continental.
So I tore everything apart, replaced pretty much everything in the front end, new rear struts, a new clutch, and some 04 STi springs for a little flair. Built myself a UEL/exhaust system while I was at it.
But of course, that wasn't enough. I had a cold start piston slap in cylinder #4 and was burning a fair amount of oil. Guess I'll just throw a good used 2.2 in there and call it good, right?
NOPE! (chuck testa)
Frankenmotor!
EJ25D Block and internals (balanced)
EJ22E single port heads with mild PNP and delta cams
Grimmspeed phenolic spacers
Cometic hybrid HGs
New OEM bearings and rings.
Group N engine mounts
300cc injectors
9mm oil pump
etc.
Continued....
Along with doing the ***************in new engine, I had to get a little more comfy in the cabin. So I opted for a set of 03 WRX seats front and rear. And if I may add, they fit perfectly, and are so comfy!
(Finally got head rests for the rears, haven't gotten any new pics though...)
I began to throw a misfire code for my cylinder #4. After a couple of months of chasing things down, I finally nailed down that running a lightened flywheel is know to cause that. Oh well, at least I have new: injectors, coil pack, wires, plugs, fuel filter, FPR, fuel pump sock, soft fuel lines, and cam sensor... Interestingly enough, at my 5k mile break in, I switched from Rotella 15w40 to Rotella T5 (semi syn) 10w30 and am getting better performance, fuel mileage, and no CEL. Odd.
So since I ran out of money in the conventional sense, I began to enjoy the car:
And that's about where we are now.
Bearing in mind, I brought the car home on January first; suffice to say I've been a wee bit busy!
Edited by cal_look_zero
Upcoming plans:
WRX Steering wheel
WRX brakes front and rear
Building some form of ram air intake that won't flood the engine during rain.
Paint... of some kind.
What boat is that? Looks like a Perception ARC?
Good to see other paddlers on here...here my brat with my greenboat on it!
  • 6 months later...
Current buildout:
Engine:
EJ25D block and stock internals; balanced
EJ22E single port heads; port matched to exhaust manifold
Delta 200 “HP Grind” cams
Grimmspeed 8mm phenolic spacers
Custom made 2” UEL and axle back.
370cc side feed JECs injectors
Exedy stage 1 clutch kit.
Perfect Power SMT-6 Tuned by Pre (123hp/145tq)
Suspension/Wheels/Brakes
Alt Rush AT362 Wheels 17x8 45ET
Goodyear Eagle GT 225/45/17 Tires
KYB Excel G struts
2004 STi springs
Paranoid Fabrications ⅜” saggy butt spacers
WRX 17mm rear swaybar
WRX brake master cylinder and proportioning valve
GSP adjustable rear lateral links and trailing arms
2002 WRX disc brake swap
Goodridge SS brake lines.
Kartboy rear subframe lockout kit.
GAB strut bars
Group N Pitch stop
Interior:
2002 WRX seats front and rear
OEM WRX underseat subwoofer
Prosport Premium 52mm oil pressure gauge
Innovate MTX-L Wideband
2002 WRX Momo steering wheel
Blox 490 shift knob
Custom built short shifter
Kartboy shifter bushings
WRX pedal covers
Pioneer Bluetooth/USB head unit
Pioneer 6 ½” door speakers (Front)
Power Acoustik 4” door speakers (Rear)
Subaru All Weather Floor Mats
20% VLC tint
Aesthetics:
Hella Supertones
Clear corners
LED license plate lights
Projector fog lights
Rally Armor mud flaps
Badge of Ownership
Holly crap!  Look at the power under the curve.  It's beautiful!  Do you have any videos?
  • 6 months later...
I... I don't know what happened man. I mean one minute I was driving along with a frankenmotor, and the next...
I've always wanted to swap an old obs. I love these cars. Swap looks super clean!
Thanks, I'm kind of way proud of it. I did EVERYTHING myself on it, built the engine from the block up, merged the wiring harnesses myself, and learned how to opensource tune it. I'm putting it on the dyno for a protune on Wednesday and will have some newer, much more impressive numbers to post up.
What crossmember did you use?
Looks like a 2L..
what is the power steering pump off of? (I am going to assume a turbo car but what model/year)
I think the remote reservoir might be the answer to my problem.
thanks
Looks like a 2L..
WRX wagon x member with stock p/s rack and shimmed stock gc control arms.
thanks
Off a bugeye WRX. I was going to run p/s-less, but it's easier to roll back to that later than to eliminate it and try to reinstall p/s later.
  • 2 months later...
Just acquired a big Perrin TMIC, a VF43 STi turbo, some TGV deletes, a 750cc kit from deatschworks, and some Tanabe GF210 springs.
Happy Festivus to me!
How do you like your prosport gauge? I'm stuck beetween that and a autometer sport comp II oil pressure gauge.. where did you mount yours by the way?
  • 2 weeks later...
You HAVE to use teflon on the threads, otherwise you'll get a bouncy reading at idle. Otherwise it's decent. I have the little pocket next to my 12v plug under the stereo, I clearanced it out and used some double sided sticky to hold the gauge in. Mounted my boost and AFR gauges on the steering column, but they're a little more important to see real time as opposed to looking down for 1/2 a second.
I'm going to use the liquid version, for the time being I will just temp mount the gauge on the side of the steering column, I plan on doing a dash gauge pod.
Have exact car and love it put outback sus all way round 2 inch lift and twin ebrake levers and no mercy beat it all day every day never let off revlimiter I tell you one tough little car 11 outa 10
