April 6, 200422 yr they don't that I know of, try lislie, mac, snapon, otc, tigertool, proto, cornwell
April 6, 200422 yr Author do you happen to have the part #'s for the mac and snap on tools that work w/ our cars? their trucks pull up a couple times a month right in front of my work. thanks
April 6, 200422 yr A friend and I just made a tool to pull the wrist pins by "modifying" a long bolt. By the time we were done, it was basically a shaft with a little protrusion that you could wedge in there and pry on a nut on the other end to get the pin out. It worked pretty well. Not the slickest tool, but it didn't cost anything. I could get a picture if you like.
April 6, 200422 yr Author A friend and I just made a tool to pull the wrist pins by "modifying" a long bolt. By the time we were done, it was basically a shaft with a little protrusion that you could wedge in there and pry on a nut on the other end to get the pin out. It worked pretty well. Not the slickest tool, but it didn't cost anything. I could get a picture if you like. yes i would like!
April 6, 200422 yr Here is a picture of the tool that I made: You can borrow it if you want mr. the sucker king. Insert it all the way through the wrist pin, let the hooked end catch the far edge of the wrist pin, and tap it out with a hammer. Very easy to make and pretty effective too.
April 6, 200422 yr I would have put a heavy piece of round hollow stock on the shaft before doing the last bend. You'd use the hollow stock (which should slide on the shaft) as a slide hammer. Saves a lot of wear and tear on the knuckles -- you would never miss! Subaru tool numbers (you can buy them from your dealer): EA82 engine: 399094310 ER27 engine: 499097300 You can use the one for the ER27 (XT6) on an EA82 engine. It's longer because you need to be able to get at the middle pair of cylinders.
April 7, 200422 yr That tool looks a lot easier to use than mine. I'll try to get a pic of mine next week when I get back home though...
April 7, 200422 yr I made a bent up one using a piece of rod like that years ago. worked ok... When I was at school last week and I needed to pull one of the wrist pins out that I had already put in (put a ring in upsidedown accidentally) I didnt have that tool on me, so I found this metric alan bolt, where the head slid perfectly down the center of the wrist pin (were talking machine fit) till it hit the notch in the center of the pin. Anyway I took a bench grinder to the head of the bolt and left about 1/4 circle on it, and it worked PERFECTLY.. I was able to attach a slide hammer to it, and get those wrist pins out in a breeze. I also had to taper the top of the head a little bit to get around the retainer clip. My 2 cents
