March 13, 201313 yr 165Kmiles; 1998 subaru outback 2.5DOHC= my friend is over my house for his problem roughly idle. The engine randomly shuts down during a drive in city-- 'when stop light or stop sign'.In addition I smell something burning as if overheating (seem oil pump failaure) OR (Catalytic Converter failure). The oil pressure light is on and oil temp light too.Plus, there is a light MIL code is O2 sensor failure and VVS. crankshaft/camshaft sensor is good ohms; 1.9K. not entierly sure what the sorcery of this is. Edited March 13, 201313 yr by Suba_GL_87
March 13, 201313 yr Author haha? what kind you think of this? Oil level is good.... when oil level light flashing on dashboard mean low pressure oil pump? Edited March 13, 201313 yr by Suba_GL_87
March 13, 201313 yr seems that there could 2-3 problems with the car but the oil pressure really needs to be addressed immediately. Someone here will be able to tell you how/where to attach an oil pressure gauge, but, in the mean time, check the oil pan for dents. perhaps the pickup in the pan has been damaged or partly blocked by something banging into the oil pan. I'd double check the car's voltage. i suppose you could consider a new oil sending unit. You should know that , oil pressure senders are set at a very low pressure, 4-5 psi. get that fixed. One source of a burning smell could be grease or fluid on the exhaust. Check for split CV boots - often the inner boot. They sling nasty smelling grease onto the exhaust.
March 13, 201313 yr You would be surprised how many people do not think of checking the oil. Did the oil look and smell ok? You can get a cheap mechanical oil pressure gauge for testing purposes, or you can mount it on the dash someplace if you want. Oil pressure right now trumps all other issues. Is there any sign of oil leaking at the front of the engine?
March 13, 201313 yr check alt and alt and alt chageing voltage ? berring failure ? have had 10 bad remand alts fail in thiss last year mostly bosch they rebiuld them and dont chage the berrings so berrings fail soon after rebiuld anyway should have 14.50 max no higher and no lower than 14volts have seen alot charging at 13.00 is to low means one bad diode and overloads the other diodes and burns wireing inside alt
March 13, 201313 yr Author ok, got you for everyone.*Alt- is good voltage! *smell like really burn there is (inside the timing belt cover) also engine very hot. when i was oil cap out and there steaming out. Coolant level is good. * no leaky oil area...Oil pan gasket drip (normal) *CV joint boots; no tearing...i know what you meaning a issue, but nothing there. i have to check oil pressure. But no where if i can loan tool for oil pressure guage.
March 13, 201313 yr This doesnt look good. I was hoping for an oil leak, a large one. YOu can buy an oil pressure gauge for less then 20 bucks, but if an engine is failing from poor oil pressure, that burning smell is what you get. The engine being hot, is that a observation or from the engine temp gauge on the dashbaord? What does the coolant in the radiator look like? What noises are the engine making?
March 13, 201313 yr sounds really bad. has this car been maintained well? any work done just before the problem came up? if you run the car with the oil filler cap off, does smoke come out regularly? I'd be tempted to confirm basics like timing belt and compression.
March 14, 201313 yr AT OIL TEMP indicates failure with transmission. My light stays flashing as soon as key is turned on. Most failures, as I have read where cause by someone using a floor jack on the fluid pan and shorting out or damaging solenoid a. In my case I had a engin replaced
March 15, 201313 yr OR, it can also flash due to a Duty C solenoid that is starting to go bad. Count the number of flashes and report back. It wil flash on initial startup and then go out.
