April 1, 201313 yr I'm gathering info about an EA71 from my Gen 1 Brat, there are a couple of things I'm not familiar with. Tell me what you see.... Pic 1
April 1, 201313 yr Author Pic 2 https://plus.google.com/photos/115985207916734462550/albums/5861931847312997169/5861939715249099666
April 1, 201313 yr Author Pic 3 http://plus.google.com/photos/115985207916734462550/albums/5861931847312997169/5861939798443480482
April 1, 201313 yr Author Pic 4 http://plus.google.com/photos/115985207916734462550/albums/5861931847312997169/5861939790778529234 First time trying to upload pictures here, still thanks for your support....great community.
April 3, 201313 yr Author Pic 4: Why is there a bump on the main block? Thank you Loyale 2.7 Turbo for the tech support....kind of dumb asking how to upload pics
April 4, 201313 yr You're Welcome my Friend. I'll Love to see your Brat Fully Restored, it is a Great Project! Kind Regards.
April 4, 201313 yr By seeing your Photos, if I were you, I would swap a Weber Carburator on that engine and I would get Rid of all the emmissions Stuff, such like Canister and EGR valve, But I believe you want to Keep it Stock, isn't it? Also, the egine's Head Gaskets might be Worn out... Have you considered a Full Engine Reseal? Kind Regards.
April 4, 201313 yr The EA71 Engine will gain more Low end Torque and Better Acceleration with a Progresive Weber 32/36 Carburator properly jetted; and will let you to Clean the Engine Bay ... Also it will Reveal its True Boxer Sound! Edited April 4, 201313 yr by Loyale 2.7 Turbo
April 4, 201312 yr Author Proyect: Take apart the whole truck down to the last bolt and rebuild....that's the idea. The Weber is a "must have" of course, the idea of keeping the Brat "stock" is to keep it "simple" just the way it was designed. If someone can confirm that pics 2 and 3 are EGR related.......those parts will be removed because I'm at sea-level. Never seen those 2 sensors on pic 1. Until I'm able to take apart the engine, the "bump" on pic 4 will keep me wondering if the valve blocks are from an EA63. Guys, thanks a lot.
April 4, 201312 yr Author Ook, I'm new at this.......is there something I'm missing about EGR, naru? Always heard that EGR is a device that can be removed from vehicules with no emission control (cat or smog test requirements).
April 4, 201312 yr Sure you can remove it,but,you need to recurve the distributor to restore stock performance. With EGR removed,ignition timing will be overadvanced under cruise conditions(when the egr operates) because of incresed cylinder filling and the resulting higher cylinder pressures. If you back off the base timing to compensate,you will lose performance under non cruise conditions(anything above about 1/3 throttle) 2nd minor issue is the increase in engine pumping losses which will decrease MPG slightly. Think of the engine as an air pump.It takes more energy to pump more air.Any air previously displaced by egr flow now needs energy to be pumped through the engine. An electric fan is a good analogy. Restrict airflow by putting a piece of carboard near the fan and you can hear the fan speed up.
April 5, 201312 yr Author I understand and thanks for the info. I live in an overpopulated city, filled with traffic lights and almost no chance to cruise, I don't want to ruin the good MPG the engine offers. Believe me gas is not cheap around here. Point taken....
