May 12, 201312 yr hi mine outback has problems and nobady does not know what is wrog when the engine is cold it does not have a power and the car is shaking we made big servis and changed oil, spark plugs, cabels, filters, distributur, cleen iac ventil (still in good working order), distributor(spark distributor) if anyone meybi know for such a problem please gave me idea what should be changed that the car will work
May 12, 201312 yr If it is missing, the Check Engine Light should be on. What is the CEL Code? Does the problem go away once the car is warmed up? With a engine code, we will be able to give you better direction.
May 12, 201312 yr 2002 outback doesn't have a MAF sensor, they're speed density. A failed coolant temp sensor could cause this. Do the radiator fans run constantly?
May 15, 201312 yr How many miles/kilometers on the car. When was the last time the timing belt was changed?
May 17, 201312 yr Author radiator fans are working normaly they are not running all the time the car has 186000 km that is 116000 ml timing belt has been done on 108000km that is 67000 ml
May 17, 201312 yr One of my first guesses here on a 2.5 SOHC would be making sure the plug wires are OEM. Aften off brand or old OEM will be bad until the engine gets some heat into it and that causes the wires to dry out and work "better". You can try taking a spray bottle after it's running o.k. and spraying the plug wires to see if any change. Over here we don't have distruibutors on those engines - so I assume you mean what we call coil pack. In my experience Diamond brand coil pack seems to be the best. Edited May 17, 201312 yr by davebugs
