ea82 cam tower oil seal question.
Is this the correct cam tower  o-ring for my ea82? I'm describing the o-ring that goes between the cam tower and the head? They were not labeled and were packaged in small manila envelopes inside the Felpro head gasket set I bought. I'm wondering about it now because there were three or four of them included in the head set.
  • Replies 78
  • Views 12.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • From what I understand from my betters, the metal reinforced gasket was introduced sometime during the production run, and obsoleted the previously used rubber-only gasket.
  • Per your PM, I pulled a couple seals from my stash-o-parts.   For those who may need to find the part number for these specials seals, the Subaru Part Number and Description are:   13089AA010
  • Thanks! Exactly the information for which I came looking!
Posted Images
the ones ive see from subaru have a copper center inside the rubber
Pretty certain that is used for something else.  (Though I can't think of what would take 3 or 4... you could look on the FelPro package's contents list.)
The proper gaskets, which I have never personally seen in a FelPro set, are flat metal washers that are coated in rubber.
Thise appear to be injector seals for ea82 mpfi.The cam tower o-ring would be the size of a dime
oops. It seems to be running good? I know they had to squish down a little when I tightened the cam tower bolts. I'll have to get the proper seals.
If they were not high temperature rated O-rings, then they will melt under high oil temperatures, and seep into the oil port in the direction of flow.  Been there, done that.
Do you mean you installed them in your cam towers already?
If so... yes... it will run ok.   But as stated above... Bad things are happening.   You just can't see it.
Thanks for your input. I HAVE noticed that my oil pressure is generally higher than it's ever been. e.g. 45 lbs @ 1000 RPM and 70-80 lbs  @ 2000 RPM. Could restricted oil passages going to the cam towers cause that?
I think I'll put a cup of used motor oil from my ea82 in a tin can and boil this remaining seal atop my coleman stove out in the middle of our local gravel pit just to see what happens. I better get a fire extinguisher first though. duh. I couldn't check the Felpro package list because the garbage man had already ran off with it.
Great. I should have read the Felpro package contents sticker. Oh well. I'll go to Subaru and see if I can get the correct seals. I'm just not the brightest bulb in Seattle. ha ha.
I should have a dozen or so.  If Subaru will take longer than Snail-mail, it might be worth having me mail a pair to you.
The old original one's I took out were thin and hard and brittle and snapped in half when I tried bending them. I didn't detect any sign of metal in them. Hmmm?
I've boiled it in water and also squished it in a vice but it bounces right back with no effect. Felpro could no-doubt have info on it also?
Just buy a couple of genuine Subaru O-rings and you will see the difference.  The engine gets hotter than boiled water.  Your engine will tell you when you better fix the problem, when it gets louder from the oil being choked off from getting to the hydraulic lifters.
I'm runnin fresh 10-40wt. in it right now. I'll update later down the road. Thanks again. vroommmm.........
13089AA010        "O Ring - CMS Case"
thepartsbin.com used to, and probably still does, carry those. but they're only $2.13 (or so) from the dealer...
My local dealer tends to not stock stuff like these.  Sometimes a pain to wait a week.
I've gone 428 miles so far with no problems. I'm amazed at how good it's been running as it was my first rodeo on a ea82 HG install. It had the common hairline cracks between the valve seats on every cylinder but I went with it anyway after researching the issue here on usmb. I did put a coat of copper spray on the HG's and I put about 3 ft. lbs. of extra torque on each head bolt after going thru the third torque sequence.
Thanks for sending me the correct seals Northwet. I'm still curious why Felpro didn't include them in their head gasket set?
You are welcome.
I have yet to see an aftermarket head set that has these... at least these correct ones.
  • 2 weeks later...
post-28702-0-18791100-1370069898_thumb.jpgI've clocked 887 miles so far since the HG replacement and its still running pristine. I better get some ambition and put the seals in.
  • 1 month later...
Update: 2,147 miles and still running strong. I've been busy at work and haven't installed  the correct cam tower oil seals yet. Two years with no vacation time makes you stronger?  :blink:
