archemitis Posted April 20, 2004 Share Posted April 20, 2004 86 hatchback 2x. i got the rear discs, and everything, with the hoses. will the hoses plug right in? or am i going to need custom lines? couldnt find anything this specific with a search. thanks Quote Link to comment Share on other sites More sharing options...
Qman Posted April 20, 2004 Share Posted April 20, 2004 Should be a plug and play. I have installed discs in 2X and 4X. Same install on both. Much better set up that surprises me Subaru didn't do. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 20, 2004 Share Posted April 20, 2004 I bet they did on some of their rally cars - that's probably why the discs are the same. The EA82 likely inherited something that was only a race or rally part (or JDM?) for EA81's. Just speculation, but it explains why they bolt up the same, even tho EA82's have radically different rear suspensions.... GD Quote Link to comment Share on other sites More sharing options...
baccaruda Posted April 20, 2004 Share Posted April 20, 2004 I just put rear discs on my 83 brat yesterday! it's easy. you need calipers and rotors (and new pads, and turn the rotors perhaps), backing plates, and hard lines. the hard lines you need are the ones off the soft hose on the caliper that run 8 inches up the rear control arm. the hard part if you're junkyarding will be finding soft lines that aren't cut. It sounds like you might have skipped getting the hard lines. Good parts stores have bulk hard line; take a caliper with you to make sure the fittings are the right size, and get a line that's about 8 inches long. You can bend it gently by hand to tailor the shape, just don't kink it. good luck. Quote Link to comment Share on other sites More sharing options...
archemitis Posted April 21, 2004 Author Share Posted April 21, 2004 no, i dont have the hard lines. im going to be doing this tomorrow nite, about 12 hours before i leave for the midwest meet. hope its as easy as it sounds. about 8 inches long huh? the drums must have longer soft lines than the discs? i have all the soft lines, and the bearings are newly greases, with no rust, its a great setup i got from carfreak85? i think is his name. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted April 21, 2004 Share Posted April 21, 2004 no, the drums have no soft line. Quote Link to comment Share on other sites More sharing options...
archemitis Posted April 21, 2004 Author Share Posted April 21, 2004 looks like i can just put a loop in the hard line, from the drum. i'll give it a try tonite Quote Link to comment Share on other sites More sharing options...
