April 20, 200422 yr Looking for a good product to rejuvinate (and protect) the rubber seals around the windows and moonroof. Should help to get rid of some of the wind noise I am experiencing. UT is VERY hot and dry all summer, much of the pliability (is that a word) is gone from my seals but they aren't cracked, just getting hard. Any ideas? dmp
April 21, 200422 yr Try using Formula 303. Here's the link: http://www.303products.com/main.php ~Howard
April 21, 200422 yr Anyone know where you can get 303 Aerospace Protectant in Oz. Google search was not very productive. Thanks Ian
April 21, 200422 yr Ian, doesn't Selleys make a similar product? When I lived in Singapore I had some good experiences with their prodcts - admittedly, this was ten years ago :-)
April 21, 200422 yr www.overtons.com has ok prices, but it is a boating store so you might get it cheaper other places.
April 21, 200422 yr I have also used a product called "Back to Black" which I think is put out by Mother's (?) No complaints, restores black color quite well. -Heikki
April 21, 200422 yr Silicone will deteriorate the rubber seals. I got Formula #303 at Strauss Auto. All of 303's products are available for purchase by mail from the company: http://www.303products.com/main.php Free samples too ! ~Howard
April 21, 200422 yr thanx for the heads up on the free samples. heres the link so you dont have any excuse not to try it. www.303products.com/main.php?infopage=freesample
April 21, 200422 yr Most of the other products eg Armor All are a dispersion of silicone oils, is 303 different?
April 21, 200422 yr OH by the way for Aussie members 303 products are reputably available from Auto One and a few boating places as well.
April 21, 200422 yr Some folks might be surprised and even balk at hearing this... but I've seen it done where old motor oil is wiped onto the exposed surfaces of body rubber seals (such as windows and trims). Leave it on for a a few hours (a sunny day helps) then wipe off the excess. They say the oil gets into the pores of the rubber and seals it against water and sun damage. I'm not saying how well I think this might work... only that I've heard of some serious 'car folks' doing it and liking the results. James
April 21, 200422 yr silicone spray lube, CARQUEST BRAND , works very good, good results, keeps seals from freezing too!
April 21, 200422 yr warning against silicone! i would not recommend it as you will not be able to paint over it. if you are gonna use it be very sure you dotn get any on the paint.
April 22, 200422 yr Yes sir! Keep silicone off the paint, but certaily smear it all over your seals. It works, and doesn't deteriorate the seals. I have been using it for over a decade and never damaged anything. I have however, successfully rejuvenated some very tired looking seals with it. From faded light grey, back to black!
April 22, 200422 yr Formula 303 works better than silicone. Give it a try. I'm sure you'll see the difference. ~Howard
April 22, 200422 yr Another vote for 303 Aerospace Protectant. I ordered mine directly from them. Works great on the vinyl too. I believe Girot's Garage (sp?) has a similar product. Commuter
April 22, 200422 yr Author So 303 it is... BUT, I will try a little silicone (as soon as I get an authoritative answer on the damage/no damage question) on one strip just to see the difference. If it is significant I will surely post pictures and results for all to see! dmp
April 22, 200422 yr I'm no chemist or plastics / rubber expert, so this is mostly 'hearsay'. It seems that silcone (ArmorAll, etc) is one of those "good point, bad points" products. It's probably better than doing nothing. It does help in some ways. It is detrimental in others. And it takes time to really see or know the difference. One is not going to be able to tell from one application. I use to use ArmorAll many years ago. I hadn't used anything on my cars for years when I got the 303 stuff. What I noticed was that it was not as greasy as the ArmorAll. It went on nice and didn't seem to be as harsh on the hands/skin. (One probably should use some vinyl gloves... *shrug*). It lasts for quite a while on the vinyl and it certainly seems to have kept my weatherstipping pliable. And I only get it on about twice a year, maybe 3 times if I'm lucky. 2 years ago when I had major work done on my car, the dealer treated me to a "car cleaning". I never asked what they used, but the vinyl didn't look as good, or stay looking good for very long. And I had a film of 'something' on the entire inside of my windows! I've heard of other products causing the more volatile constituents of the plastic to 'evaporate' and coat the windows. It certainly seems to be what happened, but I didn't recall that effect from years ago when I use to use the ArmorAll product. Whatever. It was interesting to note though. Good luck. Commuter
April 23, 200422 yr Another vote for 303 Aerospace Protectant. I ordered mine directly from them. Works great on the vinyl too. Commuter Ditto here, except I buy mine at TC's OFF ROAD in Kent. I've used it for years and this is one of those products that is worth the price. Yep it costs more.
