RWD 87 RX
I'm looking to convert my RX to rwd and I was wondering if any one could help me out on what I need to do
wellllll its pretty easy but dont expect it to last long  these trans are not meant to be rwd.
take one of the front axles out, then take it apart, take the stub shaft and put it back in the hub. then lock the center diff. bingo rwd.
if you want to make it last longer you'll need a better rear diff and a better transmission.
I circled the stub shaft, the res of the axle can be removed.
Then you will be ready for Fast and Furious 7!!!
Let us know how you go about it.
Edited by Reza
