December 3, 201312 yr Hi guys, I am new to subarus but not to cars and have some q's that i was hoping you could help me with? I am working on a 1998 Forrester with a 2.5 and bad motor, and a 92 legacy with a 2.2 and am in the process of swapping in the 2.2 into the 2.5. i am assuming that i will need the ecu and harness form the obd I and put it into the odb II car is this a doable thing or am i asking for trouble?
December 3, 201312 yr of course if you do a complete wiring swap it's doable but that's tons of work. there are a couple of easier options: 1. find a OBDII EJ22 intake manifold (95-98 EJ22), bolt it on top of the 92 EJ22 and it's plug and play into the 98 with zero wiring work. that is what i would do, and have done before. 2. you could attempt to transfer the EJ25 engine side wiring harness onto the 92 intake manifold - i *think* it's possible. the west coast folks should know as your early EJ's haven't all rusted to oblivion like ours years ago.
December 3, 201312 yr You will need to use your ej25 throttle body at the very least. Best bet would be to swap over everything between the two manifolds. The simplest way to do this conversion would be to find a 95-98 ej22 complete intake manifold, with egr because your ej25 has it and the 92 ej22 does not. There is a thread in the USRM section outlining how to work around that problem, check it out http://www.ultimatesubaru.org/forum/topic/137829-using-a-non-egr-engine-in-subaru-with-egr-exhaust-gas-recirculation-valve/?do=findComment&comment=1160910
December 4, 201312 yr Author k i have been looking at the manifolds and they look like they will swap but i am finding a cam sensor that goes on the block that will not swap any thoughts Sorry feel very dumb was just looking at the harness plugs on the back removerd and found them to be identical so just swapped them over am now starting on the maniforld swap will keep you aprised thanks for you help so far Edited December 4, 201312 yr by cmmc
December 4, 201312 yr Author ok guys I have just completed swapping everthing over between the two IM including the the throttle body and all the sensors on the block as well just need the specs to tighten down the IM again could anyone out there help me with the numbers and also the seqence. thank you once more for your help it has been invaluable
December 4, 201312 yr 18.1 +/- 1.4 ft lbs. Just do the inner ones first, after snugging them all down. O.
December 4, 201312 yr Author Thank you will be putting it in the car on thrusday so hopefully it all works.
December 4, 201312 yr If you're talking about using the ej25 manifold on the ej22 it won't work. The only manifolds that you can use are 95-98 ej22 equiped with egr.
December 5, 201312 yr If you're talking about using the ej25 manifold on the ej22 it won't work. The only manifolds that you can use are 95-98 ej22 equiped with egr. he's not. he installed the EJ25 intake manifold wiring harness onto the EJ22 intake manifold so he's retaining the manifold with the engine.
December 5, 201312 yr Author k was putting on the new clutch this morning and torquing them dowm and bang the first one snapped i am used to american v8s and thought that the cutch would be around 65lbs that is not the case i got the bolt out of the flywheel quite easily but am now searching for the right spec.
December 5, 201312 yr 23~28 ft./lbs. is what I shoot for. Snug and even is more important than drasticly tight. remember, they are just M8 bolts. Subaru Head bolts don't even see 65 ft./lbs back off a bit muscle man lol
December 6, 201312 yr Author wee haa the engine fired right up on the first try and purred like a kitten. took it for a drive yesterday down to napa and almost got stuck right off the bat(stupid winter storms). lol it ran very well with no drivablity problems that i can tell other that the check engine light is on (no egr so is going to stay on). To any one else doing this swap you will also need the alt and the ac compresser off the newer 2.5 motor as the r134a compressor will not fit in the r12 compressor bracket. just need to adjust the coolant and install the block heater cord (it was -25F here this morning) I want to thank you all for your help.
December 6, 201312 yr Glad it all worked out. If you need the CEL off for inspection, do a search. There is an egr workaround using a t from the intake manifold. O.
December 6, 201312 yr Glad it worked out as well. The thread he speaks of is the one I linked earlier.
