January 23, 201412 yr i was learning how to drive in this car and didnt know at the time that it had locking diffs for 4wd which make it very hard to turn on asphalt so i tried to turn into my driveway and ended up hitting a tree breaking my front left corner light(not just the lens, but the entire light). And now i cant find a replacement for the life of me. Edited January 23, 201412 yr by bs9024
January 23, 201412 yr I hate reading posts about people driving part time four wheel drive vehicles on pavement while in 4wd.... anywayzz should be an easy enough part to find. And cheap.
January 23, 201412 yr Im sure someone has one if you post in the wanted section. I have one set off an 86 GL but I believe they are slightly different than your Loyale so youd have to replace both or just find the one left side that you need. http://www.ebay.com/itm/1987-94-SUBARU-LOYALE-FRONT-CORNER-LIGHT-O-E-M-L-H-/390618932381?pt=Motors_Car_Truck_Parts_Accessories&hash=item5af2b3e49d&vxp=mtr#ht_475wt_918 Though geez thats expensive haha! Let me know via PM or something and I can get mine off to you for less than that.
January 24, 201412 yr Be aware, there are two different styles. I found this out the hard way on eBay. One style is for sealed beam headlights, the other is for the large plastic composite headlights. I need a left side for the seaLed beam style if anyone has one.... John
