February 3, 201412 yr It took me three different gl wagons to find my long lost love but I have finally found my keeper, 86 gl wagon with a 5 speed d/r got her lifted on a cheap DIY lift mainly just so I could get her out of my driveway and drive it around, got some 31" tires on with 2" wheel spacers and a four inch lift( 2 stock 2diy lift and yes I extended my steering shaft). More to come as I modify and pictures as soon as I have all four wheels on
February 7, 201412 yr sick offset!!! wish yokahama didnt discontinue that tire i had set on an old jeep and loved them!! then new geos dont clean as well. Edited February 7, 201412 yr by marcusgl10z28
February 8, 201412 yr Author Thanks man, i unfortunately am going to have to get smaller tires though because the rub on the front is just too much even with the spacers, anyone know of a way to get rid of this insane rub?
February 8, 201412 yr GET A BIGGER HAMMER.. seriously. i had to get a 15lb sledger to massage the fire wall on my rig. they will rub on full lock but i still have most of my turning circle. i have the same sort of offset as you. flatten the pinch weld then proceed to beat the firewall in till the tires clear.
February 8, 201412 yr Honetly... it could be the offset causing the rub... but 31"tires do tend to rub with lifts any smaller than an 8" Edited February 8, 201412 yr by marcusgl10z28
February 8, 201412 yr Author GET A BIGGER HAMMER.. seriously. i had to get a 15lb sledger to massage the fire wall on my rig. they will rub on full lock but i still have most of my turning circle. i have the same sort of offset as you. flatten the pinch weld then proceed to beat the firewall in till the tires clear. Awesome i was kind of hoping that someone would tell me that, i was just afraid that it would damage the integrity of my front end, but 15lb sledge it is
February 8, 201412 yr Very kindly, let me ask you... How does that wagon Handles on Road? ...because I see too much offset on the wheels... Kind Regards.
February 9, 201412 yr Author i drove it around the block got it up to about 40 and it handled amazing surprisingly
February 9, 201412 yr Author that's me and my dad's rebuild project it's a 66 ford country sedan station wagon (total oxymoron i know) it has a rebuilt hi pro 390 with 3 inch full dual range exhaust. need to get the gas tank refurbished and run a fuel line then she's ready for action
February 12, 201412 yr Author Went and did some much needed bashing today, but alas i think i need to jack her up 2-4 more inches for these tires to not be an issue, i may just go buy some 27's just so i can drive her around at least. Does anyone know how to get ahold of the beast i drive for his blueprints? i've tried messaging him but no luck so far.
February 12, 201412 yr He has a Phone Number under his Username, seems like he doesn't have internet for a while...
February 12, 201412 yr Author got ahold of him thank you 2.7 for the info. i totally should of looked at his profile before asking
February 13, 201412 yr ... thank you 2.7 for the info... You're Welcome! So, will you obtain the Blueprints? Kind Regards.
February 13, 201412 yr Awesome! Post photos of the Lift Kit build Process, and install, if you can... Kind Regards.
