March 16, 201412 yr EA82 head. I cannot not get two lifters out of the head. Tried compressed air, and that didn't work. Have tried everything to get these out without damaging them. They will wiggle, spin, but won't come up and out. Any ideas? Don't want to damage them, or the head.
March 16, 201412 yr More compressed air. Gotta plug the other holes to get max pressure to the stuck ones.
March 16, 201412 yr Author More compressed air. Gotta plug the other holes to get max pressure to the stuck ones. I will give that a shot. Air worked on the other two in this head.
March 18, 201412 yr Author Well, no luck. Got everything plugged best i could, and cranked up the air. Still with no luck. I had got the other two out with half the pressure, and they shot put like bullets! I don't want to damage them. I really don't want to have to take to a machine shop just to get the lifters removed, yet don't want to mess up the lifters, or the head.
March 19, 201412 yr Try a claw hammer with the claw first. It that doesn't work, then you use the business end and bust it up without nicking the cylinder head. Be gentle.
March 19, 201412 yr They spin but won't pop out? Try a little blue wrench around the cup. Or put the whole head in the oven at the lowest setting for an hour, then shoot some canned air upside down on the HLA to freeze it.
March 19, 201412 yr I have a head just the same, they spin, just won't bloody come out. Watching this post thread with interest
March 19, 201412 yr when this happened to me I vice gripped em, then sent the whole lot plus spares to mizpah...now life is good
March 19, 201412 yr I tap them sideways gently all way round this will slightly expand brass lifter bore and should let them release
March 19, 201412 yr i had same problems with my stock engine . i put a rag around them and spun it and pulled with plyers . some didnt come out so i just kept trying . gave up and the next day i tried again and the popped out with half the effort
March 19, 201412 yr I had this problem and the tops pulled off the bottom. I ended up just getting a new head.
April 1, 201412 yr Author Haven't had any luck with gettin these things out of the head. Sooo, I guess I'm gonna look for a replacement head. Anyone have a pass. side head and lifters for a ea82 around NC?
April 2, 201412 yr Use the hammer to remove the upper piston. The a file to cut a gouge into the inside edge of the upper lip. Then using a screwdriver, apply torque to the remaining base to break the bond to the head. You have already written off the head so you have nothing to lose.
April 3, 201412 yr If the body of the HLA is spinning, not just the cap/nipple.. there must be gunk/corrosion in the oiling groove holding it in. Just grab on to the body of the hla with some meaty vice grips and yank it out with force. The HLA or the sleeve will come out with force, hopefully the HLA first. I would be going medieval on that #%@$^ before writing the head off.
April 3, 201412 yr You might try soaking it in something that might dissolve a baked oil bond, like seafoam.
April 8, 201412 yr Just turn head upside and let sit, for a few hours. Most should just fallout on there own. Not to say that I didn't have a bastard that didn't come out without persuasion.
April 8, 201412 yr When compressed air doesn't work for me, I put the head on its side, grab the lifter by the shoulder( the solid part riight next to the bucket, you won't mar the metal there) with a big pair of vise grips. I grip them so the pliers are flat to the top of the head and hanging off as far as possible. Once I get a good grip(needs to be really solid), I hit the vise grips with a hammer to break the lifter loose. Usually I just keep tapping on it till it comes completely out. Works everytime and I've never destroyed one. Josh
April 8, 201412 yr They sell a can of the freeze-off stuff at most auto houses now. About 6 bucks, should cool down the HLA enough to get it past the ridge. Otherwise, the head-in-the-oven idea is clever..
April 8, 201412 yr Author And they are out!! Thank you all for the ideas! I heated the head up with a heat gun, used duster with the can turned upside down to freeze the lifter, and griped it with vicegrips, and gave them a few good whacks with the hammer and the finally came out! No damage to lifters, and no damage to the head! Woohoo
