May 3, 200421 yr well my girlfriend just pointed this out a lil while ago, i have no reverse lights on my 86 GL wagon, 5sp d/r i swapped bulbs to no effect, is it the switch on the shifter/trans, or wiring?? Thanks, Shean
May 3, 200421 yr I would first check for the switch at the shift lever. If it isn't there, then check the tranny.
May 3, 200421 yr No switch on the shifter on a 5 speed.. its in the tranny... get a multimeter and a wiring diagram and get to work.
