transmission takes 30sec to go into drive
My 2001 outback auto trans has started to take about 30sec to go into drive. Does anyone have anyone know how to fix this problem short of changing the trans. I have been told that a fluid and filter change might work. After it goes into drive everything works fine until I turn the engine off and go to start it up then the problem of the 30sec wait starts.  Need help Gunner
yes this is a very typical problem with 2001, and Trans-x is the solution.
Uhm... Have you checked the transmission fluid level? I know the ~2000 Soobie transmissions have a delayed engagement problem, but you may want to check the level first. Replacing the ATF won't hurt, though. Just make sure you fill the correct hole :)
