Legacy Suspension Mod clarification
Im looking to swap Forester struts into my 1997 Legacy L Wagon, so i can clear some bigger wheels/tires. from what i gather from reading a few threads on here, the forester struts will either bolt right in, or i will have to use the forester struts and springs with the legacy mounts.
So which is it?
Thanks in advance for your help.
The complete Forester strut assemblies were a direct bolt in on my 95 Legacy, should also be direct for yours.
Rears should be marked as to which side faces out - yes, it does matter on the rears.
Fronts not so much
I am running the 15" Forester wheels with 205/65R15 tires with zero rubbing issues (stock forester is 205/70R15 - this would have fit ok, but was mightly darn close when turning)
98-08 forester struts will bolt on. Any 02-07 impreza, 95-99 legacy, or 98-08 forester will all bolt on to each other.
