12 ton press enough for Subaru stuff?
  • 2 weeks later...
For most things that will probably work fine. For really stuck wheel bearings it may not have enough oomph.
  • 1 year later...
Any follow up on this? I was looking at a similar one at Northern Tools this morning for wheel bearings.
The 20 ton goes on sale for not much more than that. I did opt for the 12 ton, but it's still in the boxes
  • 2 weeks later...
Good call, saw a 20 ton at HF for $200. That should be enough for wheel bearings? And if the jack is junk I can always get a better one and still use the frame?
If you wait for the discounts you could get that 20 ton for $160 & use the difference toward some nice press plates like from SWAG offroad:
http://www.swagoffroad.com/ARBOR-PRESS-PLATES_p_7.html
Those arbor plates supplied with HF presses just aren't what I would call safe at any speed.
And for fabbing brackets & skid plates:
http://www.swagoffroad.com/20-TON-Press-Brake-DIY-Builder-Kit_p_40.html
Good call, just printed off a coupon for $160, think I'll pull the trigger this week.
I thought mine was less than that, but it was the cheapest one at HF when I bought it, and I don't see one for less....
Mine is plenty, I've probably done a dozen subaru wheel bearings. Lots of bushings, as well as some bearings and such. I've had a couple things fight me, but I opted to apply heat before maxing out the equipment. 12 Tons is a lot!
