using turbo HG on non turbo 2.5 sohc
I have a question: when using the 2.5 turbo HG on a non turbo 2.5 sohc engine is there a difference between the two turbo gaskets offered?
I have been using the 11044AA642 but they sold me a set of 11044AA770 which are for the STI engines.  Is there any difference?
No difference that I know of.  Subaru may simply have superceded the part number which happens all the time.
Emily
Hi,
Actually there is a difference due to a change in the head design, I believe. See (and view the differences) this LINK on NASIOC.
I came across these differences when considering an engine swap, here's what I found:
  • Head gasket: Note that HEADS should determine HG to match ports B25 vs D25 heads, etc.
  • >>>>>>> All EJ257 STI, models build dates 1/04-6/06 AND EJ255 FXT, OBXT, LGT, Baja Turbo '04-'05 - 11044AA642
  • >>>>>>> EJ255 2.5L WRX and EJ255 FXT, OBXT, LGT, Baja Turbo '06+, AND STI '07+    - 11044AA770
If the dealer stated the 11044AA770 SUPERSEDED than that 'appears' to be wrong, and the link above shows why (ports don't match).
But I don't know how this affects your SOHC NA application.
Edited by wtdash
thanks for the response.. ill check them out and see if "the ports" match up :)
  • 3 weeks later...
 I have a 98 loyal outback and would like to put a newer 2.5 turbo into it. I am a certified mechanic but I would like to know if anyone has tried it?
I put the 04 sti spec MLS gaskets in an 04 SOHC ej25 I did for a friend and they have been working fine. Didn't seem to be any significant port mismatch when I laid them on the heads. It was the weird CA emissions spec EJ259 though, with the big H6 exhaust port and 4 cats.
