sailcat Posted July 12, 2015 Share Posted July 12, 2015 computer can't communicate with abs from plug in. was wondering where to start search myself. Sensor at brakes? Quote Link to comment Share on other sites More sharing options...
jp98 Posted July 12, 2015 Share Posted July 12, 2015 I fought the ABS light in my 98 for a couple of years. It didn't hurt anything with it on so I just ignored it. Turned out being the inertia switch was bad. Quote Link to comment Share on other sites More sharing options...
nipper Posted July 12, 2015 Share Posted July 12, 2015 Which computer is trying to communicate where? The ABS systems are straight forward, look at the speed sensors and tone rings to start. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 12, 2015 Share Posted July 12, 2015 sometimes, the ABS system is the first to suffer when there are charging problems. Might take a look at that too. Quote Link to comment Share on other sites More sharing options...
mark.crowson Posted August 4, 2015 Share Posted August 4, 2015 the ABS light on my '06 Baja comes and goes. on one day; off the next Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 4, 2015 Share Posted August 4, 2015 the ABS light on my '06 Baja comes and goes. on one day; off the next when it's on - read the code. there's a grounding pin above the brake pedal - ground it and the ABS light flashes the code. look up the procedure, pins, and where to place the pin to get the light to flash. it takes like 7 minutes, just need to find the thread detailing how to do it, super easy. a sensor can be caked up with gunk or corroded, in which place you clean or replace it. might be other issues too - best to get that code when the light is on. 1 Quote Link to comment Share on other sites More sharing options...
