May 28, 200421 yr ...85 (?) Hatch, 4wd. They appear to have the same 4wd trannies. Is this the case. Looks like I need new motor mounts for the Brat and a little welding (the beast is inspected and roadable now), maybe some carpeting (!). Sources? One stop shopping? Scott 87 Gl hi-lo sedan 88 turbo wagon, LSD, GL-10 92 Justy 4wd 85 Brat
May 28, 200421 yr Same tranny, yes. Unless they are not the same model. DL's had single range, and GL's had dual range. They bolt up exactly the same tho. GD
May 28, 200421 yr The trannys are interchangable without any modification. A junkyard is your best bet for stock motor mounts. I used an EJ series mount with only minor drilling. They were the stock mounts from my Impreza that got replaced with STI mounts. Carpeting can be done at allot of shops. If you plan on mainly road use with some off road use they make a real tough carpet for convertables that is usually grey in color. If you want to go all the way I would reccomend getting the interior bedlined. I did this and added weather proof seats so now I can carwash the interior too.
May 28, 200421 yr No - some GL's are 2WD or 2WD Automatic, and others are 4WD Automatic. Only the EA81 4WD Manual's had the D/R. Same goes for EA82's, but then you get into FT4WD single and dual range and a bunch of others.... GD
May 28, 200421 yr Is this Subazoo-Scott?. If not,there's another Scott up in VT-last known to be near Tunbridge....he's set up for welding,fab,etc. somewhat and has a $200 Brat too...click on Members and contact him....if you're not him.
