ThoR294 Posted November 12, 2015 Share Posted November 12, 2015 I have done some googling and am finding some mixed information. I am driving the car home tomorrow, so I want to have everything ready so i can fix it all at once. I noticed when turning it feels like the rear wheels are locked together (like the posi unit is shot, for example). The tires are all the same size, so that is eliminated. I read that changing the fluid and adding GM Posi additive (which i have, because i have a 96 trans am) to the rear AND/OR trans??? fixes it? This is the part that confuses me, as I have no idea how the AWD subie system works. do I put that posi additive in the TRANS along with the ATF fluid AND in the rear along with the gear oil? Thanks!! Quote Link to comment Share on other sites More sharing options...
john in KY Posted November 12, 2015 Share Posted November 12, 2015 I think adding that additive to the transmission is a very bad idea. Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted November 12, 2015 Author Share Posted November 12, 2015 Yeah that is what I thought. I'm not sure how subaru's AWD system works either, so I don't know if its the rear or the trans causing the binding. This is the thread I was reading on. http://www.subaruforester.org/vbulletin/f88/do-i-have-differerential-transmission-issue-awd-binding-39121/ Quote Link to comment Share on other sites More sharing options...
john in KY Posted November 13, 2015 Share Posted November 13, 2015 As far as I know, when a LSD fails, the clutches wear out and that in no way will cause the rear end problem you are describing. The rear just becomes an open differential. May want to drain the rear and look for metal flakes.chunks. You may have damaged spider gears but that is fairly uncommon. Quote Link to comment Share on other sites More sharing options...
mikaleda Posted November 13, 2015 Share Posted November 13, 2015 you have torque bind do more research. if its an AT put your fwd fuse in. make sure your tires are matching and equally inflated Quote Link to comment Share on other sites More sharing options...
siouxbahrue Posted November 13, 2015 Share Posted November 13, 2015 I also had the shuddering you speak of. I added the "mouse oil" or GM rear end lube to the tranny fluid, and it cleared the problem in less than a mile. I was told to do a lot of figure "8s" with the car to get it to loosen up and was not required. And all this information came from a Sube Tech. Car went to 315000 miles before the head gaskets went. Bottle cost me 11 doll hairs. Quote Link to comment Share on other sites More sharing options...
siouxbahrue Posted November 13, 2015 Share Posted November 13, 2015 So to completely answer your questions: I added the mouse oil straight to the transmission fluid. Did not change the fluid at all, just put the gear oil right with it. I did this at 176k miles and never changed the AT fluid and as I said was still functional @ 315k miles. I did not add the mouse oil to the rear end diff. 1 Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted November 13, 2015 Author Share Posted November 13, 2015 Awesome thank you. Put fwd fuse in for now. Will buy additive and trans fluid. The fluid is BROWN in the car Quote Link to comment Share on other sites More sharing options...
mikaleda Posted November 13, 2015 Share Posted November 13, 2015 The fluid is BROWN in the car That's not good, that's a sign of being overheated change that fluid imediatly 1 Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted November 13, 2015 Author Share Posted November 13, 2015 I am on my way now to get fluid. 1 Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted November 13, 2015 Author Share Posted November 13, 2015 (edited) Fixed right rear caliper, replaced rear brakes. Found left rear tire has a flat spot. Could maybe cause the "torque binding?" Its bad like can't even do over 55 lol (vibration from tire). Also found the bottom parking shoe spring on right side is hitting abs wheel? It hits hard when making a right but doesn't hit when making a left. Bad bearing? Edited November 13, 2015 by ThoR294 Quote Link to comment Share on other sites More sharing options...
mikaleda Posted November 14, 2015 Share Posted November 14, 2015 It sounds like you are finding your problems. I would say from the way you explain it that it very well could be a wheel bearing. Bearings on these cars can be tricky to diagnose. First try jacking the wheel up off the ground and see if there is any side to side play or noise when you spin it. If not then driving it for a while and feeling of your hub is getting hot or not will tell you as well. Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted November 16, 2015 Author Share Posted November 16, 2015 Will do. I am going to fix the tires first... as I can't even drive the car! Picking up a set of 15" legacy WHEELS (not ugly steelies) this Friday. will then investigate wheel bearing 1 Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted November 28, 2015 Author Share Posted November 28, 2015 (edited) It sounds like you are finding your problems. I would say from the way you explain it that it very well could be a wheel bearing. Bearings on these cars can be tricky to diagnose. First try jacking the wheel up off the ground and see if there is any side to side play or noise when you spin it. If not then driving it for a while and feeling of your hub is getting hot or not will tell you as well. Welp heres an update. The grinding noise out of the right rear was the backing plate. The bottom was rusted and hitting the rotor. I smashed some of it out and cut some of it away. It is mostly gone now. It is KIND OF there, but gone. Bearings are fine. Put 4 wheels and 4 new tires on it. I can now safely go over 40MPH lol. I did a trans service, the fluid was sooooooooooo brown. I put 4 quarts in like a moron, so it was overfilled, and I added 3OZ of GM posi additive with it (spoke with a seasoned scubaru tech, he said he does it all the time to cure it). I drained it down till it was properly filled. The shuddering has toned down A LOT. It is only there at extreme turns. So maybe keep flushing it? Edited November 28, 2015 by ThoR294 Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 28, 2015 Share Posted November 28, 2015 The rule of thumb on a trans oil change is drain/fill 3x with some driving in between. Then add whatever magic elixr you want to try. Its been found that the flush has cleared up the torque bind you're suffering in a lot of cases. Subaru awd in a nutshell... Duty c solenoid controls awd. Power on, center clutch unlocked. Power off locked. Speed sensors control how often the clutch cycles. The clutch itself is a pack of discs, and plates just like the ones in the trans. My 2cents. Flush the trans 3x and put the fwd fuse in. This will let the clutch unstick if its gonna. If it still shudders, add the friction modifier. Then leave the fuse in till the shudder stops. 1 Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted November 30, 2015 Author Share Posted November 30, 2015 The rule of thumb on a trans oil change is drain/fill 3x with some driving in between. Then add whatever magic elixr you want to try. Its been found that the flush has cleared up the torque bind you're suffering in a lot of cases. Subaru awd in a nutshell... Duty c solenoid controls awd. Power on, center clutch unlocked. Power off locked. Speed sensors control how often the clutch cycles. The clutch itself is a pack of discs, and plates just like the ones in the trans. My 2cents. Flush the trans 3x and put the fwd fuse in. This will let the clutch unstick if its gonna. If it still shudders, add the friction modifier. Then leave the fuse in till the shudder stops. Makes sense. So keep driving it and flush it with the fwd fuse in? How will I know if the shuddering stops though Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 30, 2015 Share Posted November 30, 2015 Do tight figure eights in a parking lot. You'll feel the bind, and you'll know when its gone. Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted November 30, 2015 Author Share Posted November 30, 2015 (edited) Do tight figure eights in a parking lot. You'll feel the bind, and you'll know when its gone. If I put the FWD fuse in, the binding stops. The binding is only there if the car has the AWD enabled (FWD fuse pulled). are you just saying to leave the fuse in when I drive it, and only pull the fuse when i do a drain/fill? Edited November 30, 2015 by ThoR294 Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 30, 2015 Share Posted November 30, 2015 If its not binding with the fuse in i read wrong lol Leave it out while you do the flushes. I've heard it can just unstick immediately, and sometimes it can take a little time. On the flip side, it may not fix it at all. In that case you can pull the clutch and rebuild it fairly simply without pulling the trans. 1 Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted November 30, 2015 Author Share Posted November 30, 2015 (edited) If its not binding with the fuse in i read wrong lol Leave it out while you do the flushes. I've heard it can just unstick immediately, and sometimes it can take a little time. On the flip side, it may not fix it at all. In that case you can pull the clutch and rebuild it fairly simply without pulling the trans. Oops . The first flush made it sooo much better. Before it binded REALLY bad when I cut the wheel like 1/8th of a turn. I couldn't even drive the car. I had put it in FWD mode to drive it. After the first drain/fill, I am now able to drive it in AWD mode. I can feel the shudder on most 90 degree turns, but it is no where near as bad. I will try a few more drain and fills and try more posi additive. Good news on that I can rebuild just the clutch packs without re-doing the whole trans. Any recommendations on where to get the parts/write ups on how to do it? Edited November 30, 2015 by ThoR294 1 Quote Link to comment Share on other sites More sharing options...
mikaleda Posted November 30, 2015 Share Posted November 30, 2015 Check out the FAQ sticky at the beging of this forum or the usrm I beleive there is a write up in there. Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted December 1, 2015 Author Share Posted December 1, 2015 Check out the FAQ sticky at the beging of this forum or the usrm I beleive there is a write up in there. Will do. Hopefully flushing it will fix it. Currently trying to figure out why cruise randomly doesn't work Quote Link to comment Share on other sites More sharing options...
xdeadeye1 Posted December 1, 2015 Share Posted December 1, 2015 I had same problem. CHnaged tranny filter,, and drained the pan.. Didnt do complete flush.. It fixed it. I probably should do another pan drain .. Got lazy. Quote Link to comment Share on other sites More sharing options...
ThoR294 Posted December 1, 2015 Author Share Posted December 1, 2015 Always forget about the filter. I probably should do it on the last flush. http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/A-Trsax-Filter-Kit/_/R-ATP18561_0456358427 This one? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 1, 2015 Share Posted December 1, 2015 do multiple drain/refills, that often fixes them. no filter or additive needed. external filters started in 98 or 99 - so yours may or may not have an external filter. have you checked? the internal filters are pointless to replace, i wouldn't waste your time there. they aren't filters - they're just screens. they can't really clog and if they do you have far more internal damage than a filter change will ever mitigate. 1 Quote Link to comment Share on other sites More sharing options...
