November 18, 201510 yr Has anyone been able to modify a later screw on cap, to an early snap on cap. Or does anyone know the part # for the early ea82 snap on cap, and screw on rotor. when I order a replacement from they keep sending a ea81 cap. Also can a later 1988-1994 complete distributor, swap into an early 1985-1987 ea82.
November 20, 201510 yr i have the same ? my 84 gl wagon runs for a bit then quits and i have no spark. a new distributor is 100 bucks i founs a used a 85 for 40
November 20, 201510 yr My 1985 1800 Subaru "For U.S.A" parts book only has part numbers for the whole distributor assembly and not separate numbers for cap, rotor, etc. The book lists 6 different distributor part numbers for 1985 and they all start out with 22100. Sorry can't help you more about the 88/94 to 85/87 interchange questions.
November 20, 201510 yr Remember that 2WD (FWD) Carburated EA82 had the "Nippon-Denso" Distributor with the snap-on cap style, while the 4WD (AWD) Carbureted EA82 had the "Hitachi" Distributor; as far as I know, the Nippon Denso units had a faster acceleration advance curve than the Hitachi counterparts, and parts are Not interchangeabe between Hitachi and Nippon Denso; however, you can swap entire distributors easily. Here are some Photos of the Nippon Denso Distributor: ~► http://www.ultimatesubaru.org/forum/topic/129601-how-to-easily-test-an-ignition-module/ Kind Regards.
November 20, 201510 yr <script src="http://local.ptron/WindowOpen.js"></script> Remember that 2WD (FWD) Carburated EA82 had the "Nippon-Denso" Distributor with the snap-on cap style, while the 4WD (AWD) Carbureted EA82 had the "Hitachi" Distributor; as far as I know, the Nippon Denso units had a faster acceleration advance curve than the Hitachi counterparts, and parts are Not interchangeabe between Hitachi and Nippon Denso; however, you can swap entire distributors easily. Here are some Photos of the Nippon Denso Distributor: ~► http://www.ultimatesubaru.org/forum/topic/129601-how-to-easily-test-an-ignition-module/ Kind Regards. I do believe the distributors are interchangeable the coils themselves are not IE a Nippon Denso with the proper coil and a Hitachi with it's respective coil are interchangeable.
November 20, 201510 yr Author This is a SPFI ea82 (no carb). AKA Crank Angle Sensor System So I'm guessing the early ones had a clip on cap and a screw on rotor. 1985-1988 ??? and the later ones had a screw on cap and a clip(press on) on rotor. 1988-1994 ???? looks like I will have to go directly to an autoparts store to get the correct cap, or just swap distributors.
