December 19, 201510 yr replaced cluster.working.all bulbs.now no dash lights.or speedo or tach.any help
December 19, 201510 yr Well first thing I would check the connections to the cluster. Also would help to know year make and model.
December 19, 201510 yr Author the good cluster is from a 97 outback.same plug -in.everything the same
December 19, 201510 yr Author now seems to be battery and alt.to cold to mess with it anymore dam junk
December 19, 201510 yr If the charge light circuit in the cluster isn't connected that can cause your alternator to not charge. The only thing I can think would cause an issue like this is a burnt out cluster or dirty connections.
December 19, 201510 yr Possible its a fuse, but I would think everything would be dead. Couldn't hurt to check your fuses though
December 19, 201510 yr How to post pictures? - Go the box 'Reply to this topic'. - At bottom-right click on 'More Reply Options'. - At bottom left click on 'Choose Files...'
December 20, 201510 yr I use photobucket, but any picture hosting site will work. Once you upload it to your hosting site copy the image code and paste that in your reply and it will post your pic.
December 20, 201510 yr I'm not 100% sure, but I do not think the 99 cluster is the same as the 97 cluster. I seem to remember 99 being a one year only.
December 20, 201510 yr Author i have both here.the 97 and 99 both are the same where the plugs are and front
December 23, 201510 yr Author still no luck.getting cluster to.work.checked all fuses.and relays.even put in old cluster.back in.the tach worked before.but nothing now.any help
December 24, 201510 yr 99 cluster is different. the speedometer plug is different. 99 is a one year only cluster
December 24, 201510 yr 99 cluster is different. the speedometer plug is different. 99 is a one year only cluster Thus doesn't explain why the original cluster isn't working. I have a feeling something else is wrong. Have you checked all the fuses? Edit. Just reread, sounds like your plug is where the problem is. Was it damaged while pulling the old cluster? Did it click back in completely when reinserted. Edited December 24, 201510 yr by mikaleda
December 24, 201510 yr Author seems like the 97 and 99 are the same.on the back side.but the plug from car seems to small or needs another piece
