finished lift!
Can't believe the attention you get driving around!
Yes! That is what I had planned for mine, before it just 'crapped out' on me.  Height of lift?
2 inch lift with 1.5 crossmember spacers from ADF. Well worth the work and money! Way better than I expected it to be!
That thing looks awesome man!!!! Glad it worked out for you!
Patrick
Anderson Design-fab
What is your wheel/tire setup if you don't mind me asking? My GL is lifted but trying to find the right size tires to run!
looks really good.  i'm wanting what looks like the same tire size.  i dont want to have to cut anything so i'm assuming a 4inch lift cover that.  i also intend on pulling a 1500lbs travel trailer with it after all said & done
I went with ADF 2inch with the 1.5 inch crossmember spacers. And im running 29 inch at3's. i had to cut quite a bit but it only rubs when i get close to full steering lock. or im bouncing pretty hard. still very driveable for everyday use. i have had no problems so far. but i do get more attention than if i ran down the street naked.
Welcome to the lifted red wagon club, Where did you get the headlight eyebrows for yours?
I just taped then off and put a light coat of off brand plasti dip on it look pretty good even up close. And the light shines right through no problem
I just taped the headlight off, then put a light coat of off brand plasty dip and the light shines right through looks good!
