January 19, 201610 yr I did the engine swap a couple of years ago. Sold it to a fellow at work. He had the knock sensor P0325 & misfire on #3 P0303 pretty random for over a year. I suggested the normal: NGK Copper Plugs NGK Spark Plug Wires Gave him a knock sensor to put on gave him a set of fuel injectors to swap in He wanted to sell the car, so I got it back. He had not followed my advice on the NGK plugs and wires so I installed a set and drove the car for a couple of weeks. I sold it to another family friend the they drove it for over a month before the P0325 & P0303 codes came back. There is a slight miss, but over all runs well. About 210K mileage, 5sp. I have not adjusted the valves or taken a compression test. Other things? Thanks, Larry
January 20, 201610 yr Yes seafoam down the intake could knock carbon of off a valve and cure a missfire. I've done it before, could use water as well.
January 20, 201610 yr I had the same thing happen with my 99 when I swapped. There was a small crack in the knock sensor. But you said you replaced it so my next thought could be what happened on my 91 when I swaped engines. The single blade that is in one side of the connector for the knock sensor got pushed out the back a little so it never seated in the other connector. Just a thought
January 20, 201610 yr Author New knock sensor on order. I swapped in a used one, that ohm out correctly. New one going in and a seafoam treatment.
January 20, 201610 yr Hi, Depending on your 2.2 - HLA vs SLA - I'd check the valve clearance if SLA.....easy(er) to do on the SOHC. If you've got the Leak down tester, I'd do that and a Comp. test as a 'health check'. GL TD
