January 31, 201610 yr I've been through the archives a few times and can anyone confirm that these Empi Axles will fit a 85 EA81 GL Hatchback. thanks Jonas http://www.amazon.com/Empi-80-5515-Joint-Half-Shaft-Assembly/dp/B007XOV3B6/ref=sr_1_1?s=automotive&ie=UTF8&qid=1454126743&vehicle=1983-13-59-20---8----2----6-0&sr=1-1&ymm=1983%3Asubaru%3Agl&keywords=80-5515
January 31, 201610 yr This chart may help. http://www.ultimatesubaru.org/forum/topic/73038-axle-replacement-for-ea-series-cars/page-2?do=findComment&comment=629117
January 31, 201610 yr Author So a<script src="http://local.ptron/WindowOpen.js"></script> This chart may help. http://www.ultimatesubaru.org/forum/topic/73038-axle-replacement-for-ea-series-cars/page-2?do=findComment&comment=629117 So according to your chart I should use the 87AC axle for carburated 4WD?
January 31, 201610 yr Yes, looks like you need the 87ac axle. You can compare it to what you currently have to verify.
January 31, 201610 yr Author Here lies my problem... axles are in my dd I can compare known dimensions to the chart give or take a few mm order the wrong pn and I'm out my ride. Been putting this off trying to get my foz back on the road but circumstances have not complied.
February 1, 201610 yr Go to Knechts. I've gotten plenty of axles from them. About the same price. Have them cross ref. with a 1984, or just get '84 axles, should be the same.
February 1, 201610 yr Author Jonas, funny that's my name too. Hows the quality with the ones from Knechts good bad similar?
February 2, 201610 yr Ive only gotten one really bad one thru them. Easier than dealing with amazon for return/exchange. Never as good as origionals. Its usually the same empi axles on amazon.
February 3, 201610 yr Get oem axles. Just returned 3 of 4 amwi I believe. Maybe they were empi... Total hassle. The fourth is starting to act up after a week of use.
February 4, 201610 yr Author Called the local dealer and the EA81 axles are not available from them. I figured the price would be the deal breaker though.
