October 26, 20169 yr HI, Just wondering if you guys do anything special as far as preventing rust. I dont think anyone undercoats their cars anymore. The salt tears up the vehicles underneath and the fenders and rockers. My dad would put crude oil in a pump garden sprayer and spray the underside of his work vehicles and he claimed success. Anyone else do this? Have another remedy you use?
October 26, 20169 yr When I had an older car I prayed, then when the rear quarter started to bubble I sanded it and spray painted caution stripes over it.
October 26, 20169 yr Salt is the real killer. Under coating isn't done anymore. It was really made for sound deadening, not rust proofing. Your dad had the right idea of using oil as a barrier method to prevent salt from getting into direct contact with steel to form rust. Just like how a condom works. Washing the salt from the car helps a lot, but not too practical in the dead of winter when the temp is below freezing level.
October 26, 20169 yr Author yeah , He said the paraffin in the crude would help seal it,, Don't know if its fact. maybe ill just google it. lol
October 26, 20169 yr i fluid filmed mine plus on the rear quarter i removed the little trim strip around the wheel well because its just a catch all for the salt and dirt
October 27, 20169 yr I've been using Hammerite Waxoyl for many years. Stops and prevents rust. Great for areas that don't show. Soaks into places you can't get to. On my Loyale wagons, I noticed how the mud flaps and part of the fenders trap dirt and crud. So I modified them to block the path stuff was getting in, and made sure there is a way for it to drain out. On the newer models, watch out for plastic pieces that cover and "protect" areas near the bottom / wheel wells. They hide the rust until its too late.
October 27, 20169 yr Depending on what you want to protect from rust, the best I've ever found is a product called Dynaflux 309. That product stops rust on everything and it's on all my bolts, frames, dampers, AYC/ACD pumps, etc. The color is grey but can be painted. I bought a case of 12 spray cans in the past for $160 (Canadian) which was including tax/shipping on Amazon.ca. Now it's about $240 for the same so about $20/can but well worth it regardless. Spray oil as your father did to keep costs down, but use the dynaflux for any valuable metal part..
October 27, 20169 yr Dynaflux produces a hard Zinc coating that will stop rust and protect all metal from corrosion. It's equal to hot galvanizing. I'm so glad I found this product. It really works, and if you have the $'s, do the total underside of your car.
October 27, 20169 yr BTW,, if you use this product please review the safety concerns and use the appropriate safety masks...you don't want to breathe a hard zinc coating into your lungs. Edited October 27, 20169 yr by coryl
November 2, 20169 yr Really. I spent so much money refinishing and repainting interior bolts/frames which totally rerusted...I hate any reddish color on my cars. Dynaflux 309 is the only thing that stopped this from happening.
