Scott in Bellingham Posted November 28, 2016 Share Posted November 28, 2016 So I picked up 92 legacy wagon with automatic high gear doesn't work ,I have a 96 trans from another leg wag will it work in there? Is ther any differences? Quote Link to comment Share on other sites More sharing options...
montana tom Posted November 28, 2016 Share Posted November 28, 2016 Lot of changes between 92-96 , i'm guessing here, but I doubt it could communicate with the ecm. Others may have done a similar swap and have more info for you. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 28, 2016 Share Posted November 28, 2016 1993-1995 4EAT's have the same wiring harness: http://parts.subaru.com/p/Subaru_1995_LegacyL-Wagon/HARNESS-ASSEMBLY-TRANSMISSION/49234043/24029AA131.html with some wiring, these guys have put 4EAT's into EA vehicles and a guy on subaruxt.com did as well into an XT6: http://www.ultimatesubaru.org/forum/topic/106406-installing-an-ej-tcu-4eat-into-an-ea-car-4eat/ is the 92 a speedometer cable, while the 96 has a speed sensor? Quote Link to comment Share on other sites More sharing options...
wtdash Posted November 29, 2016 Share Posted November 29, 2016 Hi, It'll work, but different FD ratios for 4EATs. '92-'94 Legacy (incl. Turbo) = 3.9; '95-'98 Legacy L/Brighton 4.11; '96-'98 Legacy GT/LSi/OB = 4.44. '99 is Phase II/2 4EAT = stay away. You must match the rear diff. User your '92 TCM/TCU. '96 speedo cable is electronic, but just swap in the '92...same connector. SEARCH on here to confirm...but I've read more than once that'll work. 1 Quote Link to comment Share on other sites More sharing options...
