WJM Posted June 15, 2004 Share Posted June 15, 2004 Ok....what are the factory struts? Gas, or liquid? Aftermarket....you have a choice of gas and liquid....but most aftermarket OE style replacements are....what? gas or liquid? In this place where you can get all kinds of race car goodies...ive seen different 'weight' damper fluid for motorcycles...most notibly its for motocross and the like... Here is what I was thinking, could it be possible (yes it is, anything is possible for me!!!!....but lets try to get realistic for once... ) to drill a hole in the stock struts...drain the hopefully thin fluid...tap the hole so a plug can screw in....then fill the strut back up with thicker stuff....thereby hopefully increasing the dampening rates...?????????????????? It seems that....upon my last search...no one was willing to revalve/rebuild the stock or aftermarket stuff....at all. The aftermarket stuff avalible is NOT going to be suitible for my endeavors in suspension modifications....AGX and GR2 is what I hear is avalible for the front and rear respectibly. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 15, 2004 Share Posted June 15, 2004 Factory stuff is all gas to my knowledge - generally made by KYB or Tokiko (whoever that is). Just my ovsevations from looking at a lot of struts and shocks on Subaru's. GD Quote Link to comment Share on other sites More sharing options...
WJM Posted June 15, 2004 Author Share Posted June 15, 2004 The RX stuff is KYB, and the non RX is the Tok stuff....i believe that the WRX and such is KYB as well. Quote Link to comment Share on other sites More sharing options...
samo Posted June 15, 2004 Share Posted June 15, 2004 KYB AGXs are excellent shocks/struts. The Nissan crew has been using them for years, with nothing but great results. They have adjustable damping, which is always nice. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 15, 2004 Share Posted June 15, 2004 My Brat, and my wagon both had KYB factory struts and shocks. It's a mixed bag from what I can see. GD Quote Link to comment Share on other sites More sharing options...
WJM Posted June 15, 2004 Author Share Posted June 15, 2004 Ok, gas ones... what if I vacant the gas, and pour in some thin fluid....????? increased dampening rates? Yay or nay? Quote Link to comment Share on other sites More sharing options...
All_talk Posted June 15, 2004 Share Posted June 15, 2004 I think the valving for gas will be very different than what you would need for oil. You might start with aftermarket oil struts and attempt a oil switch, but I doubt you could drill and tap the cartage with getting some metal inside which would lead to a quick seal failure. I’ve been doing some thinking on this issue, the back is no problem as its really a coil over set up, revise the upper mount and the options are endless. The front is the real challenge, I think the best solution would be to find a cartage style strut that would fit inside a modified stock strut tube. If the cartage was sourced from modern sports car there should be a good choice of performance options. For direct fit stuff the RX struts are stiffest, and I think KYB has RX spec replacements. I haven’t really looked into it to deeply yet, if I come up with any thing I’ll be sure to post. Gary Quote Link to comment Share on other sites More sharing options...
