darsdoug Posted May 30, 2017 Share Posted May 30, 2017 Anyone know if the AC panel from a 91-94 Legacy will work in my 90 Legacy? Mine bought the farm. It's not soda pop gumming up the buttons either. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 30, 2017 Share Posted May 30, 2017 Open it up and resolder the board connections for the harness connector. It's easy. GD Link to comment Share on other sites More sharing options...
darsdoug Posted May 30, 2017 Author Share Posted May 30, 2017 Open it up and resolder the board connections for the harness connector. It's easy. GD Yes that's gotta be it. I noticed if I slanted it a little when lifting it out (before unplugging the pigtail with key on) all the buttons and fan switch kicked back on and off and on again. Thanks. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 31, 2017 Share Posted May 31, 2017 Yep. I've only fixed a few dozen of them ;o) GD Link to comment Share on other sites More sharing options...
wtdash Posted May 31, 2017 Share Posted May 31, 2017 And FWIW, I believe ONLY the '90-'91 are interchangeable......'92-'94 are different enough to not work (plug wiring,etc) although they look/function the same from the driver's seat. Link to comment Share on other sites More sharing options...
darsdoug Posted June 1, 2017 Author Share Posted June 1, 2017 And FWIW, I believe ONLY the '90-'91 are interchangeable......'92-'94 are different enough to not work (plug wiring,etc) although they look/function the same from the driver's seat. There's one on eBay for sale but I'm hesitant to purchase it. (91-94) Link to comment Share on other sites More sharing options...
darsdoug Posted June 1, 2017 Author Share Posted June 1, 2017 (edited) Yep. I've only fixed a few dozen of them ;o) GD I checked it today and all the solder points appear good. I'm starting to wonder if it's just a problem with the connector? Yes I may go bonkers soon. ha ha. Edited June 1, 2017 by darsdoug Link to comment Share on other sites More sharing options...
wtdash Posted June 1, 2017 Share Posted June 1, 2017 Didn't read it all but maybe the LC crew can help HERE. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 1, 2017 Share Posted June 1, 2017 (edited) You may have to look at them with high power magnification to see the cracks. Just remelt them and try it. GD Edited June 1, 2017 by GeneralDisorder Link to comment Share on other sites More sharing options...
darsdoug Posted August 24, 2017 Author Share Posted August 24, 2017 (edited) I pulled one from a 91 Legacy wagon and yes indeed the connector was different. Went to pic n pull and got one from a 89-90 wagon and all is well. Edited August 24, 2017 by darsdoug Link to comment Share on other sites More sharing options...
