May 30, 20178 yr Anyone know if the AC panel from a 91-94 Legacy will work in my 90 Legacy? Mine bought the farm. It's not soda pop gumming up the buttons either.
May 30, 20178 yr Open it up and resolder the board connections for the harness connector. It's easy. GD
May 30, 20178 yr Author Open it up and resolder the board connections for the harness connector. It's easy. GD Yes that's gotta be it. I noticed if I slanted it a little when lifting it out (before unplugging the pigtail with key on) all the buttons and fan switch kicked back on and off and on again. Thanks.
May 31, 20178 yr And FWIW, I believe ONLY the '90-'91 are interchangeable......'92-'94 are different enough to not work (plug wiring,etc) although they look/function the same from the driver's seat.
June 1, 20178 yr Author And FWIW, I believe ONLY the '90-'91 are interchangeable......'92-'94 are different enough to not work (plug wiring,etc) although they look/function the same from the driver's seat. There's one on eBay for sale but I'm hesitant to purchase it. (91-94)
June 1, 20178 yr Author Yep. I've only fixed a few dozen of them ;o) GD I checked it today and all the solder points appear good. I'm starting to wonder if it's just a problem with the connector? Yes I may go bonkers soon. ha ha. Edited June 1, 20178 yr by darsdoug
June 1, 20178 yr You may have to look at them with high power magnification to see the cracks. Just remelt them and try it. GD Edited June 1, 20178 yr by GeneralDisorder
August 24, 20178 yr Author I pulled one from a 91 Legacy wagon and yes indeed the connector was different. Went to pic n pull and got one from a 89-90 wagon and all is well. Edited August 24, 20178 yr by darsdoug
