September 6, 20178 yr So my 2000 forester seams to be possessed,... for starters it doesn't seem to matter where i place the shifter,... i.e. 1-2-3-D it will still shift all the way to 4th gear at regular RPMS as if it was in Drive. Second when it goes to downshift up a hill or passing it falls out of gear,..revs up past 4 grand then slams right back into the gear it came from, and lastly the torque converter is not locking up at all.. This thing has me perplexed,.. I'm a pretty good wrench but I'm not auto trans wiz. any suggestions are appreciated.
September 6, 20178 yr is the car new to you or has there been a wreck or work done recently? any chance the wrong fluid was drained or refilled? have you checked the trans fluid level? It's the only fluid you check while idling - otherwise it shows too full. any warning lights on or blinking? Edited September 6, 20178 yr by 1 Lucky Texan
September 6, 20178 yr Author i purchased the car with a blown axle, and the alarm system stuck immobilize, Replaced the axle, bypassed the alarm system. Trans fluid was low when i got it running, and i have topped it off with fresh, checked while warm while idling. Car has a clean title, and i ran the vin after purchase, it came with records including a full trans service from Meineke within the last 20k miles. No warning lights or codes at this time.
September 6, 20178 yr maybe try some fresh fluid - 3 drain/fill cycles get sabout 85% new fluid - on the last fill, try a bottle of Trans-X. Folks report it helping with delayed engagement but, your car's symptoms seem quite severe. Have you tried a batt. neg terminal disconnect to reset the TCU?stuck immobilizer makes me wonder if a reversed-wire jump or something fried the TCU? Or did meineke screw something up? Edited September 6, 20178 yr by 1 Lucky Texan
September 6, 20178 yr Author The TCU was also something I suspected. Although I'm not sure how I would go about testing it? The trans fluid looks fresh and new as as does the spin-on filter perhaps changing the fluid again would help but the suggestion you made about possibly being jumped backwards and smoking the TCU and the immobilizer sounds quite possible.
September 6, 20178 yr I read in another thread that the TCU is usually on the steering column behind the knee panel? Maybe get one from a junkyard or try car-part.com ? oh! make sure the green and the black 'diagnostic' connectors haven't been connected - though I'm guessing you'd have fans and relays cycling on-off. really, I am out of my element, just throwing out some guesses, hope an experienced guru responds here.
September 6, 20178 yr Author ill check on the that TCU location when i get home, as far as the Diag. connectors those are not plugged in, like i said above i'm a pretty good wrench but auto transmissions are not my forte' but for some reason this appears to be something common that's making the transmission behave like a neanderthal, and TCU is a good suspect. However the fluid change is in its future i'm sure
September 7, 20178 yr If you can slide under there, check the trans mount & shifter assy / bushings, might be loose. Have a friend inside so they can move the shifter and help you locate things.
September 20, 20178 yr Author Update! i climbed under the car to examine the inhibitor switch as its called (its acutely a combination PRND321 position switch) upon removal of the switch i bench tested it as per the FSM and found it to be faulty, this would also explain why it will not start unless i hot wire it. Will have a new switch in hand tomorrow and will update with results.
September 20, 20178 yr We used to call that the PRNDL switch back in the old 2-speed automatic times... I saw one of them powerglides where the case was made out of cast iron, HOLY COW I always wondered how heavy those were!
September 21, 20178 yr Author Ok! Good News the Inhibitor Switch took care off many of the issues, i can now start the car with the key, the back up lights now work, the torque converter locks up at proper intervals and i can manual shift the car as it now is aware of what gear its in. However it still downshifts like a mad teenager in a honda trying to pass a bus, as in it comes out of gear revs up to about 4 grand then falls into the desired lower gear violently. could that possible be the line pressure resistor located on the passengers strut tower? slowly getting closer to making this thing road worthy
