EA82 dicconected now fast idle!
My egr has not done much work since installed in a clean condition
15000 km if that
Just disconnected it to see if it was cause of lumpy idle and started up first time today, drove off to find once warmed up she idles about 1200 - throttle body vac port plugged.
So connected egr again to find idle back to 800
Something dicky in the egr me thinks
Never had one do that. Not that it can't.
Check the CTS , those can mess with idle, and not cause a code while doing it.
Sorry should explain engine is in Brumby and only circuitry be in the den so dizzy.
Blanking plate three bond cured overnight runs at 1200 so adjusted until I get new egr
Egr delete did not give me any noticeable power gains but now have lurvley smooth idle even down to about 600 rpm
Something not had since this engine went in this beast after sitting around for a bit
Got a decent 18 InHg on the gauge as a result. Happy jono
Consider this + feedback :)
Well, getting best fuel economy so far...see if it continues, or balances out next fill :D
If you can google the john bennet cooling system, he was doing radical things with EGR, like porting them out to increase its contribution at the right moments gaining economies, addressing cavitation caused by water pumps, recirculating coolant bypassing the radiator and getting cooler running systems, thermostat in the lower hose like EJs, and gaining power increases
Mind you, an egr valve is a service item and I bet if i fitted a new one ......
