93 legacy over heating. Ive tried everything
Do not buy ANY gaskets from ANYONE but the dealer. Got it?
Reuse the head bolts.
Mahle is junk. Nippon Reinz makes the factory gaskets.
Ok got it. So intake manifold gasket. Head gasket. And valve cover gaskets and make sure they are are from the dealer. I got all that. Ill reuse the head bolts. And have the heads resurfaced. Anything else?
Reseal the breather plate on the back of the block.  You should have the aluminum one already.
93 would likely be the yellow plastic plate. I've seen them on 93/94's.
That can be done without pulling it too?
no
Between engine and trans.
Pull the engine.  It makes the HGs easier.
Gotta throw yourself into this and make things happen. You’ll feel WAY better on the backside of things.
Look how much support and advice you’ve gotten already.
Make us proud ! I know money is tight , same here brother. But this is why we all knuckle bust and support each other.
Gather up the $ and throw yourself into it. You’ll have a great boost in pride afterwards.
