Does the 82 brat only use one wheel bearing seal?
Recently bought an 82 brat. Engine runs well, but need to replace a stripped hub to be able to drive it. I am replacing the bearings and ball joint while I am at it. I noticed there was only an outer seal and no spacer between the two bearings (just the built in spacing of the knuckle). Is this normal? Or should I buy both an inner and outer seal?
Also would buys some hubs if anyone has any that reads this.
Thanks!
There probably should be a spacer. Older and newer cars had them.
There should be an inner and outer seal.
