May 17, 20187 yr I need to adjust the throttle cable in my car but the part of the sleeve that clips to the firewall is broken, rendering any adjustment useless. If any members live outside the US, would you please run this part number for me to see if its still active? 37114FA070 - Throttle cable This is the part number for a 1993 WRX Type-RA throttle cable, but I'm not 100% that is what is on this car. (It's not a EA82 or EA82T cable, that is certain.)
May 17, 20187 yr No longer available. Looks like the aftermarket may be available. Likely 37114FE000 for a later model will work and Megazip shows as available. Additionally, a USDM cable may work. https://www.megazip.net/zapchasti-dlya-avtomobilej/subaru/impreza-2161/gdae-6570/gda-4hd-553037/accel-cable-7083482#/il-164685460-5264745-5264745
