Power outlet on 90s era subes?
Hey all. My cig lighter power plug is shot, will be replacing ASAP, but I was wondering if anyone had successfully wired into a 90s era, mine is a 95 legacy L wagon, but a power outlet of any sort?
possibly one of the later power outlets I see advertised?
just wondering. I’d sure rather have 110 plugs rather than the adapter thing.
thanks
’97
What ever you wire in, make sure you have a fuse between it and the main harness of the vehicle.
I've put in all sorts of things in my L series - double USB charge ports (permanent power from second battery), stereo, interior lighting etc.
All you have to do is work out if you want it on with accessories or when the ignition is in the ON position.  Then decide if the load of the device will require a relay to run power from the battery with good wiring (with a fuse as close to the battery as possible).
Check out some youtube clips on DIYing this stuff - it should be pretty easy going if you follow some basic "rules".
Cheers
Bennie
